Can this optimization problem be solved?
The discussion revolves around an optimization problem involving a binary matrix and a cost function that depends on the connections between elements. Participants explore various methods for solving this problem, including brute force, simulated annealing, and potential linear formulations. The context includes theoretical considerations and practical implementation challenges.
  • One participant describes a minimization problem involving a binary matrix and a non-linear cost function, questioning the feasibility of using conventional solvers.
  • Another suggests that for small values of N, a brute force numerical solution could be effective, while also mentioning that costs can be computed and fed into any solver.
  • There is a query about whether the elements of the cost function are non-negative, to which it is confirmed that they are.
  • Simulated annealing is proposed as a suitable method for larger matrices, with the caveat that it may not guarantee the optimal solution unless run extensively.
  • A participant expresses interest in formulating the problem as a standard optimization problem for efficiency.
  • One participant discusses the specific context of the problem, relating it to resource allocation in a multiagent system and the implications of shared resources on costs.
  • Concerns are raised about generating feasible solutions for the matrix M while adhering to constraints, and the complexity of ensuring unique states in the simulated annealing process is highlighted.
  • There is a discussion about whether to use MATLAB's optimization toolbox for simulated annealing or to implement the algorithm independently, with considerations of ease of use and understanding.
Participants express multiple competing views on the best approach to solve the optimization problem, with no consensus reached on a definitive method or solution. Different strategies such as brute force, simulated annealing, and potential linear formulations are discussed without agreement on a single approach.
Participants note the complexity of the problem due to the non-linear nature of the cost function and the constraints on the binary matrix. The discussion reflects various assumptions about the feasibility of different optimization techniques and the computational challenges involved.
This discussion may be useful for researchers and practitioners in optimization, operations research, and multiagent systems, particularly those interested in resource allocation problems and algorithm implementation strategies.
smehdi
Hello, I am working on an optimization problem but I am not sure if the problem can be formulated and solved with conventional solvers.
Assume the minimization problem for a set of elements ##\mathcal{N} =\{ 1,\dots, h, \dots, i,\dots, N \}##
\mathrm{minimize}\quad C = \sum_{i=1}^{N} \sum_{j=1}^{N} m_{ij}.c_{ij}
$$ in which ##m_{ij} \in \mathbf{M}##.
##\mathbf{M}## is a binary ##N\times N ## matrix such that ##m_{ij}=1## says the element ##i## is connected to element ##j## and its cost ##c_{ij}## is defined as $$ c_{ij} = \frac{a_{ij}}{1+\sum_{n=1}^{\color{red}{i}} m_{nj}} - \sum_{h=1}^{i} \frac{ m_{hj}. a_{hj}}{(1+\sum_{n=1}^{h} m_{nj}) (2+\sum_{n=1}^{h} m_{nj}) }$$ in which ##a_{ij}## and ##a_{hj}## are given.
In a simpler case, we can consider
$$ c_{ij} = \frac{a_{ij}}{1+\sum_{n=1}^{\color{red}{i}} m_{nj}} - \frac{ m_{hj}. a_{hj}}{(1+\sum_{n=1}^{h} m_{nj}) (2+\sum_{n=1}^{h} m_{nj}) }$$ for a given ##h##.
In other words, the cost of connecting to element ##j## for element ##i## depends on how many elements are connected to ##j## and if a particular element ##h## is connected to ##j##.
Every element must be connected to at least one other element and ##m_{i,i} = 0, \forall i \in \mathcal{N}##.
In fact, such a matrix has to be found $$
\mathbf{M} =
\begin{bmatrix}
m_{11} & \dots & m_{1j}& \dots& m_{1N} \\
\vdots & \dots & \vdots & \dots & \vdots \\
m_{i1} & \dots & m_{ij} & \dots& m_{iN} \\
m_{N1}& \dots & m_{Nj}& \dots& m_{NN} \\
\end{bmatrix}.$$ I am looking for the optimum result and the solver is not very much important.
Actually the main problem is that the denominator of the second part of ##c_{i,j}## is non-linear and I am wondering if it can be converted to a linear form or it can be solved by a solver as it is.
Thanks.
If N is not too big, you can find "brute force" numerical solution.
The code is simple. No "conventional solver" is needed.
Or, you can find Cij and then feed any solver with them.
Are they non-negative ?
This problem screams "simulated annealing" in my opinion. For large M's where you can't brute-force every single combination(computational time for evaluating 2^(N*N) combinations will blow up fast) ,it will give you results that are really good (close to global minimum), but may not be THE optimal solution(Unless you run it long enough to evaluate all combinations)
It is not very difficult to implement either. If you are going for this alternative, I will be happy to answer more of your questions.
Other than that, if you manage to get a linear problem, you could use the Branch-and-bound method with LP relaxations. Dunno if you could do something similar for a nonlinear problem, but in any case I think simulated annealing is the better option(and easiest) option.
Where did you come across this model?
Thanks, ##N## is around 20.
"brute force" should work but I am looking for a more efficient way to solve the problem.
Actually I am trying to find a way to formulate it as an standard optimization problem.
All the ##a_{i,j}, i,j \in \mathcal{N} ## are non-negative.
Thanks. "simulated annealing" is a good candidate to use. I will work a bit more to see if I can find an easier way, preferably in an standard optimization form.
The problem comes from distributed control for resource allocation in a multiagent system. When an agent uses a resource, the efficiency of the network depends on whether the other agents use the same resource or not. For instance, when two agents can be served by one resource, the cost assigned to each agent is less than that of assigning one resource per agent, as the denominator depends on the number of agents using the resource. In this case, assigning lower cost to the agents results in saving resource for the whole system, i. e., one resource is required for the whole system instead of two. The cost function that I am using is a very specific form of the Shapley function.
What I am trying to find is the global optimum point for the system, as a centralized approach. It will be used as a benchmark for distributed algorithm to see how good the distributed approach works compared to the global optimum.
Well, I am going for simulated annealing but I have some questions regarding the implementation of this algorithm.
I have a couple of constraints for ##M##, like ##\sum_{j \in \mathcal{N}} m_{i,j}=1## and some more.
I think I have to first find a feasible ##M## based on my constraints and then give it to SA algorithm. In this case, how ##M## is generated will also be very important. In fact, ##M## must be generated in a way to somehow, by considering the constraints, go all over the feasible region in order to make sure that we do not miss the global optimum. Moreover, ##M## must be completely random but at a same time an ##M##, generated and rejected at any step by SA alg., must not be generated again. Then I think it would be a bit complicated and consumes huge memory and also the run-time would be very high. right? :confused:
Another issue is that MATLAB optimization toolbox has the SA algorithm implemented. Based on your experience, is it better to use the MATLAB optimization toolbox or I should write the code by myself?
I wouldn't bother with making sure that an M is not generated twice.
I haven't tried the MATLAB version, its probably good. It does not take many lines of code to implement the algorithm, but maybe it takes some time to understand it.
I did not know that you had constraints. It basically just means that you have to be a bit clever about how you define your states and/or the part of the algorithm that chooses a neighbour states.
If I understood your constraint right, one only has one nonzero entry in each row? With the constraint you gave, one way of choosing states and neighbours is : Let j(i) be the column index of the non-zero entry in row i. You can then choose a neighbour state by 1. Pick a random row, 2. move non-zero entry in that row to the left or the right in the matrix with even probability(unless you are looking at the first or last column, in which case it can only go one way).
  • · Replies 26 ·
  • · Replies 0 ·
  • · Replies 27 ·
