Can throwing trash into lava solve our landfill problem?
  • Thread starter Thread starter gfd43tg
34 replies · 5K views · last reply
gfd43tg
With the news about the Hawaiian volcano eruption, it got me thinking: what if we just put our trash down an active volcano and let it incinerate? I know there is a logistical problem getting trash to lava / into a volcano, but would there be toxic emissions if we just threw our trash into flowing lava? I am curious in principle. Did I solve the global landfill problem?
What would be the difference between this and using a waste incinerator?
Incinerators usually have legislation relating to environmental standards and emissions, which would be difficult to match with a volcano.
See here for example.
Lava is still rocks. It's denser than most anything you would want to dump rather than recycle. So, you're asking if uncontrolled grilling of assorted rubbish in open air would produce toxic emissions.
I guess the difference is the volcano is already spewing out lava, and we don’t need to build an incinerator facility and burn additional gas just to burn the trash. The volcano is doing the work for us. How do we control emissions from a volcano right now?
The point is the emissions from the burning waste are toxic or extremely potent greenhouse gases., which is why there are standards on emissions from incinerators.
Have a look at the literature review https://www.researchgate.net/profile/Sandra_Huber/publication/267737177_Emissions_from_incineration_of_fluoropolymer_materials_-_A_literature_survey/links/5458c34d0cf2bccc4912a34c/Emissions-from-incineration-of-fluoropolymer-materials-A-literature-survey.pdf, for an example of some of the compounds produced.
There's a similar article here about the emissions from burning PVC.
In an incinerator, these emissions can be controlled to a much greater extent by further treatments than would be possible at a volcano.
If the trash is submerged into the lava, can the gases get trapped inside and once the lava hardens to a rock the greenhouse gases will just be trapped inside the rock? Kind of like a tree absorbing and storing CO2
How would you achieve that?
If the idea is to use the lava to incinerate waste the issues are the toxic byproducts released into the atmosphere. If the idea is to submerge the waste in lava so that it is sealed away once the lava solidifies then you've basically invented a landfill with a crazy amount of extra danger.
Well in a landfill the trash is still physically present and piling up. In submerged lava the trash is reduced to ashes and the gas (hopefully) is trapped inside. So we would just have a growing island that has pockets of gas inside of it. It’s like a forest of trees holding CO2, it’s better than the CO2 accumulating in the atmosphere. Maybe the lava is hot enough to decompose the gases into base elements?
TeethWhitener said:
I would advise you to pay attention to @Bandersnatch 's previous responses.
I get the density thing. Maybe we just have to push the garbage into the lava to get it under. Can I can get on a surfboard and go riding down lava and I won’t submerge into it?
Are you less dense than lava?
Edit: ...ignoring the fact that you'd burst into flames or vaporize pretty quickly.
What happens if the volcano erupts, as they are won't to do?
It is far easier and safer to simply recycle what waste is recyclable and incinerate the rest.
European countries are already doing this. Sweden, for instance, sends less than 1% of household waste to landfill. The percentage that can't go to landfill is because incinerating the byproducts are simply too toxic, which would still be too toxic to incinerate in a volcano.
Why would the lava hold the gaseous byproducts? You can’t have it both ways, you can’t simumtaneously prevent physical pile up and somehow reduce the waste to ash.
Another angle here:
Without being able to speak for the more densely populated countries in Asia, landfill volume problems in the west are more political/NIMBY issues than anything else. Global warming concerns are changing how they are viewed though, since the greenhouse gas they emit - methane - is also a valuable resource. So towns can make money and generate electricity from them, while reducing GHG emissions.
You've got it a bit backward. You want to put the trash into a subduction zone rather than a volcano.
In a subduction zone, it gets carried deep into the Earth, mixes and reacts with what's down there, and doesn't reappear on the surface for a billion years or more.
Cross-section diagram of a subduction zone: a subducting plate dips beneath an upper plate, with labels for volcano, melting, ash cloud, landslides, tsunami, locked interface, great earthquakes, fluids, intra-plate, outer-rise, plate and motion.
  • Cross-section diagram of a subduction zone: a subducting plate dips beneath an upper plate, with labels for volcano, melting, ash cloud, landslides, tsunami, locked interface, great earthquakes, fluids, intra-plate, outer-rise, plate and motion.
I can’t put my finger on a source, but I seem to remember this being suggested as a solution for nuclear waste disposal some time back.
It sounds like that should work in principle. But the devil is in the details, and I don't think anyone knows enough about the details to be sure. The required level of how sure is sure enough would be higher for nuclear waste than ordinary trash.
TeethWhitener said:
(one-handed post while feeding a baby)
Multi-tasking, huh... :smile:
@Maylis -- Your Profile page says that you have a BS in Chemical Engineering. I'm a bit confused by some of your posts in this thread, given your technical background...
For example, if you were to fall into a lava, you would simply land on top without submerging and burn on the spot until you vaporize. You probably wouldn't see anything like the terminator giving a thumbs up.
Stuff like plastics can easily produce environmentally hazardous emissions. Are you suggesting we should build some emission regulating facility on top of a lava? That sounds very costly and unrealistic. If you throw something large scale like wastes from a city, you risk uncontrollable small eruption that would probably damage the facility and quickly make them useless.
Brilliant! So I’m not totally off base here. Just need to figure out how to get it on the plate that is sliding into the earth. My guess is the pressure is so high down there that the gas will stay dissolved in the mantle. Also need to make sure we don’t get back pressure pushing the flaming trash back out.
As @russ_watters said, the main issue with properly maintained landfills in developed countries is NIMBY-ism. Treating the waste and storing it isn't a particularly pressing logistical problem. Plus, the cost of engineering a subduction zone disposal scheme for regular waste would be astronomical compared to current waste management costs.
From the google search that @Bystander provided, I'm gathering that the main objection to storing nuclear waste in a subduction zone is that those areas tend to be earthquake-prone and otherwise geologically unstable. Plus you have to worry about high-pressure salt water corroding whatever container you've put your nuclear waste in.
The relevant usual speed is around a few centimeter for a year. So you need to contain that 'trash' for some hundred thousand years.
Also, to put the containers in place you need to work some kilometers underwater.
We can't do that even for nuclear waste.
If you want to 'burn' trash then it would be better to use some biology instead. Less of a firework, but you might get more usable material.
Denser the fluid, more is the buoyancy and the gas won't just remain 'trapped' in the lava... At least not long enough for the lava to solidify
I think the more pertinent example here would be poor Smeagol (not) sinking into the lava river of Mount Doom ;)
Speaking of Terminator 2 - the lore has the T-800 made of some sort of titanium alloy. So it'd not only not sink gracefully down the molten steel as depicted, it likely wouldn't even melt. It'd just lie there awkwardly, with the Connors standing above in the haze of burnt flesh, pondering if perhaps not paying attention in science classes wasn't such a good idea after all.
