Can Variable Coefficients Be Used in Geometric Series Sums?
8 replies · 2K views
RJLiberator
I am giving the sum:
k=1 to infinity Σ(n(-1)^n)/(2^(n+1)
first term/(1-r) = sum for a geometric series
[/B]
With some manipulation of the denominator 2^(n+1) = 2*2^n I get the common ratio to be (-1/2)^n while the coefficient is k/2.
The first term is -1/4. This i am confident in.
When I apply the relevant equation, my answer is -1/6.
When I use wolfram alpha calculator the answer is -1/9.
There seems to be something wrong with my manipulation, I have a few guessed:
n/2*(-1/2)^n is my manipulation.
Is it possible to have a variable on the outside of the ratio when applying the geometric series sum? Does the geometric series sum even apply to a problem like this?
Thank you.
The index probably shouldn't be k, since the terms being summed all involve n.
In any case, this is not a geometric series.
[/B]
Thank you.
Damn.
I am guessing that this is NOT a geometric series because it depends on a variable outside the common ratio (k)?
I am also concluding that I need to use the alternating series sum?
RJLiberator said:
Damn.
For a geometric series, an = r*an - 1. You don't have that with the series in this problem.
It is an alternating series, yes, and you can get an approximation to the series by adding the first few terms in the series. I think that's what you're talking about.
Hm. An approximation adding the first few terms...
How would I go about finding the sum (as exact as possible) using calculus II methods?
Nothing
Nothing comes to mind. What's the exact wording of the problem? For many of these kinds of problems, they want you to estimate the sum, accurate to, say, four or five decimal places.
First, change the problem to ##S(x) = \sum_{k=1}^{\infty} (-1)^k k x^{k+1}##; you want ##S(1/2)##, but it is a lot easier to see what is happening if you use ##x## in place of ##1/2##. So, write out the first few terms of ##S(x)##:
[tex]S(x) = -x^3 + 2 x^4 - 3 x^5 + \cdots[/tex]
Try writing ##S(x) = -x^3 \, T(x)##, and write out the first few terms of ##T(x)##. Do you now see what is happening?
@Ray Vickson
Why do we want S(1/2) when the interval is -1<x<1 ?
Wouldn't that s(x) that you wrote out be represented by the first few terms of
-x^2+2x^3-3x^4 and so on and not what you wrote? Or am I missing something here.
Unfortunately, I am not sure what is going on with T(x). I will look more into it when I have time tonight, but if you can offer guidance (or a link) that would be great. :)
RJLiberator said:
@Ray Vickson
Well, YOU wrote ##\sum_{k=1}^{\infty} (-1)^k k (1/2)^{k+1}##, and that is just ##S(1/2)##.
As to ##T(x)##: the only guidance I am willing to offer is to tell you to sit down and actually write things out. Don't waste your time looking for links or other advice---just do it.
And YES, it should be -x^2 + 2 x^3 - ..., not what I wrote. So S(x) = -x^2 * T(x).
