Can We Practically Measure the Gravitomagnetic Effect with Spinning Cylinders?
  • Level: Undergrad
  • Thread starter Thread starter olgerm
    Experiment
66 replies · 8K views
olgerm
I was thinking about an experiment to demonstrate gravitomagnetic effect. I did my calculations using gravitomagnetic model. It is not as accurate as general relativity, but GR should give similar predictions. I do not know if it would be possible to to this experiment in real life(are there enougth accurate sensors and tought materials).
installations consists of three spinning cylinders. first to cylinders are for creating a magnetic field. last one is for detecting gravitomagnetic field. last cylinder under axis 90 degrees angle compared to first two cylinders.
gravitimagnetic field created by first two cylinders right between the cylinders: ##B_G=\frac{\mu_G \omega_1 \rho_1 (r_2^2-r_1^2)}{2}##
  • ##\omega_1## is angular speed of 1. and 2. cylinder.
  • ##\mu_G##is gravitomagnetic constant ##\mu_G=\frac{2 2\pi G}{c^2} \approx 9.33\ 10^{-27} N/kg^2 s^2=9.33\ 10^{-27} s/kg##
  • ##\rho_1## is density of 1. and 2. cylinder.
  • ##r_2## is 1. and 2. cylinders outer radius.
  • ##r_1## is 1. and 2. cylinders inner radius.
torque on third cylinder because of gravitomagnetic effect is crosswise to its angular speed and angular speed of first two cylinders.
##\tau=\frac{2\pi \rho_3 (R_2^4-R_1^4) \omega_3 B_G}{2}=\frac{\mu_G \omega_3 \rho_3 (r_2^2-r_1^2) 2\pi \rho_1 (R_2^4-R_1^4) \omega_1}{4}##
  • ##R_1## is 3. cylinders inner radius.
  • ##R_2## is 3. cylinders outer radius.
  • ##\rho_3## is density of 3. cylinder.
  • ##\omega_3## is angular speed of 3. cylinder.
What you think what is the highest value for ##B_G## and ##\tau## we could practically get?
Derivation of equations
gravitimagneticfield:
I used formula ##B=\mu n I## from http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/solenoid.html. Using similarities between gravitomagnetism and electromagnetism: ##B_G=\mu_G n I_G=\frac{d^2m}{dl dt} \mu_G=\mu_G \frac{d^2m}{dl dt}=\mu_G \int_{r_1}^{r_2}(dr \rho v(r))=\mu_G \int_{r_1}^{r_2}(dr \rho \omega r)=\mu_G \rho \omega \int_{r_1}^{r_2}(dr r)=\frac{\mu_G \rho \omega (r_2^2-r_1^2)}{2}##
magnetic moment:
I used formula ##m ={\frac {1}{2}}\iiint _{V}\mathbf {r} \times \mathbf {j} \,{\rm {d}}V## from https://en.wikipedia.org/wiki/Magnetic_moment .
using similarities between gravitomagnetism and electromagnetism: ##M_G={\frac {1}{2}}\iiint _{V}\mathbf {r} \times \mathbf {j} \,{\rm {d}}V##
##|M_G|={\frac {1}{2}}\iiint _{V}r \frac{d^2m}{dl dt} dV=\frac {1}{2}\iiint _{V}r \rho v dV=\frac {1}{2}\int_V r^2 \rho \omega dV=\frac {1}{2}\int_{R_1}^{R_2}h r^2 \rho \omega 2\pi r dr=\frac {h \rho \omega 2\pi}{2}\int_{R_1}^{R_2}(r^3 dr)=\frac{2\pi \rho (R_2^4-R_1^4) h \omega_2}{8}=\frac{2\pi\rho(R_2^4-R_1^4)h\omega_2}{8}##.
torque:
I used formula ##\tau=M\times B## from https://en.wikipedia.org/wiki/Magnetic_moment
using similarities between gravitomagnetism and electromagnetism: ##\tau=4 M_G\times B_G##
What youyhink what would the highest ##\rho## and ##\omega## values practically possible?
olgerm said:
What youyhink what would the highest ρ\rho and ω\omega values practically possible?
What do you think? Have you looked up properties of any materials you might use, like density and tensile strength? Have you calculated what the stress in the material would be at various rotational frequencies?
olgerm said:
highest value for τ
How long is a piece of string?
Clearly the smallest torque you could measure on a watchspring is smaller than the smallest torque you could measure on a planet.
Much more readable than last time, thank you. However, note that this is incorrect
olgerm said:
##\mu_G##is gravitomagnetic constant ##\mu_G=\frac{2 2\pi G}{c^2} \approx 9.33\ 10^{-27}N/kg^2s^2
It should be ##\mu_G=4\pi G/c^2\approx 9.33\times 10^{-27}\mathrm{N kg^{-2}s^2}##. And some use of the paragraph maths mode ($$ instead of ##) and the eqnarray environment would also help. So instead of this
you get$$\begin{eqnarray}
|M_G|&=&{\frac {1}{2}}\iiint _{V}r \frac{d^2m}{dl dt} dV\\
&=&\frac {1}{2}\iiint _{V}r \rho v dV\\
&=&\frac {1}{2}\int_V r^2 \rho \omega dV\\
&=&\frac {1}{2}\int_{R_1}^{R_2}h r^2 \rho \omega 2\pi r dr\\
&=&\frac {h \rho \omega 2\pi}{2}\int_{R_1}^{R_2}(r^3 dr)\\
&=&\frac{2\pi \rho (R_2^4-R_1^4) h \omega_2}{8}\\
&=&\frac{2\pi\rho(R_2^4-R_1^4)h\omega_2}{8}
\end{eqnarray}$$
I haven't had a chance to think about the details of what you wrote - I will have a look. Obvious comments given what we worked out last time are that you are assuming that your cylinders are infinitely long and that your small cylinder is infinitely small in an infinitely narrow gap between the two cylinders. How sensitive is your maths to the lack of infinities in reality?
As I noted, you need to think about the field from a pair of finite cylinders with a finite separation. That'll get you a revised ##B_G## and hence a revised expression for ##\tau##. Incidentally, where did the 4 come from in the last expression in your OP?
But this new ##\tau## will depend on a lot of variables - ##\rho_1##, ##r_1##, ##r_2##, ##L## (the length of cylinders 1 and 2), ##\delta## (half the gap between cylinders 1 and 2), ##\omega_1##, ##\rho_3##, ##R_1##, ##R_2##, ##h##, and ##\omega_2##. You need to constrain these somehow. A few constraints are easy:
  • At least for a first pass I'd set ##r_1=R_1=0##.
  • You can set ##R_2=\delta##, so the perpendicular cylinder fits exactly between the co-axial ones - don't worry about clearances at this stage.
  • Unless you want to go into details of the off-axis field, I'd just require ##h\ll 2r_2## - maybe set ##h=r_2/2##.
A more complex constraint is that you don't want your cylinders to disintegrate. You need to look at the stresses in a spinning cylinder (Google is your friend) and require that they be below the yield stress of the material. That'll give you an expression for you ##\omega##s in terms of the sizes, densities, and yield stresses of your cylinders.
Then you just play around. Look up some material densities and yield stresses and plug them in. That should mean that you now have an expression for ##\tau## in terms of just three variables ##r_2##, ##L##, ##R_2##. You can add another constraint by insisting that the volumes of the cylinders are some constant determined by your budget for buying materials - so now you have a function of only two variables (times a few different materials). Plug a range of values in and see if you can find the combination that gives you the best ##\tau## - optimisation algorithms will help, but you could just brute force it.
Optionally, you could plug in a maximum energy for spinning the cylinders, which would limit the range of cylinder sizes possible given your rotation rate. If you don't do that, definitely check that you don't have stupid energy requirements!
That'd be my approach, anyway. Then you could see what kind of ##\tau##s you can actually generate on cylinders of known mass, and we can think about whether detecting them is plausible at all.
For simplicity I assuma that 1. and 2. cylinders are much larger than 3. cylinder.
Ibix said:
How sensitive is your maths to the lack of infinities in reality=
Not very sensitive.
I do not know for sure how to calculate maximum rotational speed from tensile strength. Maybe someone who has some experience could give me order of magnitude.
I won’t do that, but I will tell you how to arrive at such an estimate for yourself.
consider a small volume at the edge of the cylinder, surface area ##dA## and thickness ##dR##. What is its volume and mass? What is the radial acceleration needed to keep it on its circular path? What force is needed to produce that acceleration? That force is more or less evenly distributed across the surface area... you can take it from here
Ok. But your torque depends on ##R_2^4##. Insisting that ##R_2## be small seems like a mistake to me.
olgerm said:
Not very sensitive.
Perhaps you could show your maths for this? My quick calculation suggests that for a fixed mass of metal I can get an order of magnitude variation in ##B_G## by varying the aspect ratio of the cylinders.
##{\displaystyle {\frac {E}{I}}=K\left({\frac {\sigma }{\rho }}\right),}## is not helpful because it is about kinetic energy not generated GM-field.
##B_G=\frac{\mu_G \rho \omega (r_2^2-r_1^2)}{2}##, but
##E_{kinetic}=\frac{\rho\ \omega^2\ 2\pi (r_2^4-r_1^4)\ h}{8}##
B_G is proptional to ##r^2##, but kinetic energy is propotional to ##r^4##.
On top of everything else, I am not sure that conceptually this is correct. Which way does the third cylinder want to rotate? And why?
(If you say "because of the right-hand rule" as part of your answer, my next question is "and where does that come out of GR?")
Ibix said:
And rotational kinetic energy depends on...
You mean ##\frac{E}{I}=\frac{\omega^2}{2}##
so ##\omega=\sqrt{\frac{2\ K\ \sigma}{\rho}}##?
It seems wrongbeacause omega does no depend of r.
Could you just write correct expression for maximum ##\omega\ r^2##?
because of the right-hand rule. I use Gravitoelectromagnetic model, which is approximation for GR where gravitational fields are small.
As @Vanadium 50 was hinting in post #15, a human choice of convention for how to represent things, which is what the right hand rule is, cannot have a physical effect. So this answer cannot be correct. The right-hand rule can't make things rotate a certain way.
Good point - that does seem odd. You could check another source, or you could work through Nugatory's method (which was more or less what I had in mind when I proposed this above).
No, because I haven't worked through the maths myself. Happy to check yours when you've done it.
Articles are important. It is an approximation, not the approximation.
I am not convinced this is a valid approximation. I'd want to see an explanation for the direction that Cylinder 3 turns.
I didn't think I'd need to say this, but OK, "where does that come out of GR?"
Vanadium 50 said:
I am not convinced this is a valid approximation. I'd want to see an explanation for the direction that Cyliner 3 turns.
Depends on the sense of rotation of cylinders 1/2 and 3, I think. You could look at pairs of ingoing and outgoing geodesics near the pole of a Kerr black hole, I guess?
I'm also slightly concerned that this is applying a non-coaxial torque to a spinning cylinder - i.e. a gyroscope. In other words you'd need to look for precession, which is likely to look very like vibration from the spinning...
I'd like to know where it comes from.
What I suspect is happening is that the rotation causes terms to cancel at first order (for every mass element moving at v, there is one moving at -v) so the terms we neglected in getting to geomanetism become important. But let's start with the simpler question: clockwise or counter-clockwise.
And for extra fun, if I reverse all three spins, which way does it rotate?
Torque on 3. cylinder is crosswise to angular speeds of 1. , 2. and 3. cylinder.
##|\tau|=\frac{2\pi \rho_3 (R_2^4-R_1^4) \omega_3 B_G}{2}=\frac{\mu_G \omega_3 \rho_3 (r_2^2-r_1^2) 2\pi \rho_1 (R_2^4-R_1^4) \omega_1}{4}##
No, because opposite moving sides have opposite displacement from centre. Same way that solenoid magnetic field is not canceling out altougth there are opposite current on different sides from centre.
I guess I don't understand your objection here. Gravitomagnetism certainly seems to predict that the third cylinder will attempt to rotate - the "magnetic" field of the two coaxial cylinders is parallel to their axis and the "magnetic moment" of the third cylinder is perpendicular to that, which produces a torque perpendicular to the plane defined by the cylinder axes, and hence rotation in that plane. Which way it goes I don't know without keeping track of signs which I haven't bothered to do, but I'm not sure what doing so would add. Here's a sketch of my understanding - red arrows represent the spins of the cylinders and green the "magnetically" induced rotation of the small cylinder:
As noted I haven't checked the signs of the rotations for consistency, and the small cylinder is a gyroscope so it'll start to precess rather than rotate steadily in that plane - but I think that's how this model says it'll start moving. I'd expect changing the sense of the rotations of the large cylinders or the small cylinder to reverse the sense of the green arrow; reversing both would leave the green arrow unchanged. Or am I missing something?
I admit I haven't seen a derivation of gravitomagnetism from the EFEs - my quick reading has only provided a derivation by blunt assertion (Newtonian gravity looks like a Coulomb field so perhaps there's a gravitational analogue for the magnetic field - originally a proposal by Heaviside, I think).
I see no reason why this formula should be correct for a solid cylinder. You assume the field is the same as a soleniod for no reason that you've explained, logically.
That formula also doesn't seem to match the Wiki's formula for the gravitomagnetic field of a rotating body. See for instance https://en.wikipedia.org/w/index.ph...ravitomagnetic_fields_of_astronomical_objects.
Wiki's formula does not have a reference, unfortunately, so it may be incorrect too.
I'm a bit unclear why you need or want three cylinders. Your diagram isn't really clear to me, reverse engineering of what I think you should be doing suggests two cylinders should be enough.
[add] Ibix's 3d diagram seems clear, if that's what you're suggesting, I don't see the need for three cylinders.
One cylinder is needed to generate the gravitomagnetic field, the second is redundant. A second is needed to measure the torque. But your diagram isn't clear enough that I'm confident that you're doing what I think you should be doing.
Note that the torque will be proportioanl to the mass, so what you're really looking for is the precession of a gyroscope caused by the gravitomagnetic field.
Gravity Probe B already has done a test of gravitomagnetism. So I'd suggest looking at the GP-B experiment rather than trying to create your own. Their test is rather similar to the 2-body version of the test I think you are suggesting, omitting the third unecessary body. There's a brief overview of GP-B at
https://einstein.stanford.edu/content/fact_sheet/GP-B_Nutshell-0307.pdf has a summary.
I won't get into the results of GP-B, except that it was felt that the experiment did confirm gravitomagnetism, in spite of some unexpected experimentally glitches with their gyroscopes having less than ideal behavior.
The first thing you might want to think about motivationally is whether or not you can create a gravitomagnetic field in a lab that's stronger than that produced by the rotating Earth. You'll need a convicing formula for the field in order to do that - I am simply not conviced that your use of the solenoid as a an exemplar is correct.
As I suggested earlier, you also need reasonable physical limits on your spining bodies - bodies that spin so fast that they'd fail to hold together are not a reasonable test candidate.
So in summary, I expect that something vaguely similar to what you're proposing has already been done, Namely GP-B, and it has already confirmed the existence of gravitomagnetism.
The objection is that I am not sure the gravitomagnetism approximation is correct here.
[A-level digression]The "right-hand rule" or a "cross-product" is a statement of an anti-symmetric tensor in the problem. In EM and GR these come in different places: the Faraday tensor is intrinsically anti-symmetric, where in GR it comes in as the anti-symmetric piece of the Lense-Thirring metric. There is no reason to believe that these lead to the same result.[/A-level digression]
Because this thread (and its predecessor) involved tossing equations and values around willy-nilly, it's not clear that the rationale leading to gravitomagnetism applies here. In gravitomagetism, one says "I have a particle of mass m and velocity v. If I want a Lorentz-invarient theory, I need a Lorentz-like force on this particle, so I need a 'gravitomagnetic field'. All other terms are small and can be dropped."
That is not the case we have here. Linear momentum is zero. Linear momentum on one side of the cylinder is canceled by the opposite linear momentum on the other. It may be that the expression is still correct (or maybe off by a factor of 2 or something) but it is far from guaranteed. The "large" term is zero, and the effect is from the "small" terms.
An order-of-magnitude guess is that since this is second order in v (e.g. L2/2I), the size of the effect relative to Newtonian gravity is ~β2. If the cylinder surfaces are moving at 1000 mph, the effect is a few x 10-12.
The question about reversals is an attempt to tease out the parity properties.
Let's assume Cylinder 3 rotates clockwise in the green direction.
If I reverse the spin of the big cylinders, the rotation becomes CCW. Now reverse the spin of the small cylinder, and it's CW again. It looks to me like a parity-odd transformation, which is a peculiar outcome from a parity-conserving theory.
I would like to getestimation on maximum ##\tau## and ##B_G##. For that I need maximum ##\omega_1\ \ \rho_1\ (r_2^2-r_1^2)## and maximum ##\omega_3\ \rho_1\ (R_2^4-R_1^4)##.
Do you think ##\omega=\sqrt{\frac{2\ K\ \sigma}{\rho}}## is correct?
if it is then
##|\tau|=\frac{2\pi \rho_3 (R_2^4-R_1^4) \omega_3 B_G}{2}=\frac{\mu_G \omega_3 \rho_3 (r_2^2-r_1^2) 2\pi \rho_1 (R_2^4-R_1^4) \omega_1}{4}=\frac{2\ K\ \sigma\ \mu_G\ (r_2^2-r_1^2) 2\pi\ (R_2^4-R_1^4)}{4}##
