Can we solve this Morin's problem without conservation of string?
13 replies · 3K views · last reply
member 731016
For this problem,
Diagram of an Atwood machine with four massless pulleys hung in a staggered arrangement from a ceiling bar, each labelled m at the free end of its string, with the two strings ending at the labelled masses.
The solutions are,
Two-page solution excerpt from Physics Olympiad Handouts: derives the string constraint x = -x'/8 and acceleration a = -a'/8, then gives a' = 56g/65 and a = -7g/65 using tensions T1 = 2T2 and T2 = 2T3.
However, how would we solve this without using the idea of conservation of string? Can we apply Newtons second law to each mass?
My working is:
Diagram of an Atwood-style pulley system with three movable pulleys hanging from a ceiling bar, tensions T1 to T5 labelled on the strings, and masses m and mg marked at the two hanging ends, with handwritten red annotations.
Then apply Newton's Second Law to each pulley,
Equation T1 + T2 = mg, written in LaTeX-rendered mathematics.
(Line 1)
Equation T2 = T3 + T4, with T2, T3 and T4 written as tension symbols with subscripts.
(Line 2)
Equation T4 = T6 + T5, with T4, T6 and T5 written as italic symbols with subscripts.
(Line 3)
Equation written as T7 = T5 + mg, with subscripted tensions T7 and T5 and the term mg.
(Line 4)
Many thanks!
  • Diagram of an Atwood's machine with several pulleys hanging from a ceiling bar, tensions labelled T1 to T5, and two masses labelled m at the bottom ends of the strings, with handwritten red annotations.
I don't think your setup is quite right. Just looking at your first equation, you've set the tensions upward equal to gravity downward. This equation says they're equal, and the mass shouldn't move. You need an equation that gives it freedom to move. It should probably have an ##a## in it somewhere.
I don't ever remember using conservation of string to solve Atwoods problems. I could be misremembering, though.
Thank for your reply @BiGyElLoWhAt ! I will update that.
If string isn't "conserved" (rather than created from nothing, maybe think of it being infinitely stretchable, like some sort oif idealized version of Silly Putty) the left three pullys will all fall to the floor. There's no tension in the strings because string length is not conserved, No solution.
It seems to me that equation of line 4 is not correct.
T5, T6 and T7 must have the same value.
Can you visualize the system of pulleys as an instantaneous arrangement of levers?
If so, you could easily understand the relation of the external forces (mg left and mg right).
Thanks for your replies @Vanadium 50 and @Lnewqban ! Are you saying that the solution given by Kevin Zhou is incorrect? Many thanks!
"Correct" vs. "incorrect" isn't the way I would look at it. I would ask "are you solving the question asked"? When you remove the constant string length constraint, you allow the string to stretch, and with no constraint, your pulleys end up on the floor.
This means you don't want to give up that constraint.
Callumnc1 said:
View attachment 318431(Line 1 fixed?)
View attachment 318432(Line 4 fixed?)
Are the lines fixed now @Lnewqban ?
Many thanks,
Callum
It seems that line 1 was correct as shown in post #1.
Without solving the whole problem, I would not know how correct lines 1 and 4 are as shown in post 7, sorry.
Why do you want to solve this without using the idea of conservation of string?
I think he's asking whether or not it's possible, meaning whether it's necessary to utilize that fact or not. I'm not sure that it is, now that I look at it more closely. Without actually solving it, I think you are going to end up with more unknowns than you have equations for.
As for equations 1 and 4, those look correct to me now, other than the fact that you have labeled your accelerations to be the same. You should give each mass it's own acceleration, or couple them together with another equation, probably involving the tensions.
I think the issue with trying to apply N2L here is that the pulleys are massless, they can't obey N2L, as any force would give rise to an infinite acceleration. You would need someway to work around the lack of mass, and effectively turn it into a kinematic equation, which I believe is one of the points of "conservation of string". Now you have equations dealing with distances (string lengths) as opposed to forces.
In general, if you have N variables, you should expect N equations to be able to get unique solutions, if they exist.
Thanks for your reply @Lnewqban , no worries! I want to solve this without conservation of string too see if it is possible to solve the problem with two methods.
Many thanks,
Callum
Many thanks,
Callum
You are welcome.
Try the system of imaginary levers described in post #4.
Locate the fulcrum of each lever at the point of each pulley that does not move for the imaginary very small period of time.
Then, for each pulley, you will have two more points to which forces are applied.
Note that you problem has three strings.
All pulleys look alike, but some serve only for changing the direction of the rope/cable/chain, while others act as levers, reducing the pulling effort in half and doubling the length of rope to pull.
Thank you @BiGyElLoWhAt , that was what I was trying to ask! Also thank you @Vanadium 50 for the stuff you said on string constraint! Also why would massless pulleys not obey Newton II?
According to this Physics SE post, Newton II is obeyed by massless pulleys [well at least the way I read it! :) ]
Screenshot of a Physics Stack Exchange answer by Bob D, text stating it is OK to apply Newton's second law to a massless pulley, with the phrase highlighted.
https://physics.stackexchange.com/q...m#:~:text=Yes it is OK to,if its mass is zero.
Many thanks,
Callum
Lnewqban said:
You are welcome.
Thanks again @Lnewqban - I will try the system of imaginary levers at some point!
Many thanks!
