Can x be equal to the square root of its own absolute value?
  • Thread starter Thread starter basil32
    Proof
The discussion centers on proving that the absolute value of x, |x|, is equal to the square root of x squared, sqrt(x^2). Two proofs are presented: the first uses the property of square roots, while the second considers two cases based on the sign of x. The importance of establishing that both x^2 and |x| are non-negative is emphasized, as this is crucial for applying the definition of square roots. The conclusion follows from confirming that a = |x| and b = x^2, satisfying the conditions needed for the proof. Overall, the proofs aim to validate the equality |x| = sqrt(x^2).
basil32
Prove that |x| = sqrt(x^2)
I've written two proofs but I don't know if they can be justified as real proofs or whether they are valid or not.
Proof 1:
\surd x^{2} = \surd \vert x \vert ^{2} = \vert x \vert
Proof 2:
First Case ) Suppose x \geq 0 then \surd x^{2} = x = \vert x \vert
Second Case ) Suppose x < 0 then \surd x^{2} = -x where -x > 0 therefore -x = \vert x \vert
Let's look at the definition of the square root:
If a2 = b and a ≥ 0, then a = √b. Now look at your problem. What two things do we have to prove?
That x^{2} \geq 0 and \vert x \vert \geq 0 ?
The two bolded things are what you want to prove. Once you have those, then the conclusion follows. Before you do anything, what is a in your problem? What is b? Once you have a and b, what is the first thing you need to prove?
a = \vert x \vert and b = x^{2}
a^{2} = \vert x \vert ^{2} = x ^ {2} = b
a = \vert x \vert which is nonnegative. correct?
Correct.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
