Can XP Be Installed on a Computer with Windows ME?
  • Thread starter z4955
    Computer
16 replies · 5K views · last reply
z4955
I'm having probs reformatting a computer with win 2000
every time I put the win 2000 disk into install windows I a gray box comes up: this installation must be installed to run. Plz run Setup fron the location where is originally installed the application
so you mean I can't reformat the computer with this cd?
so in order to reformat the computer I need to reformat it with windows ME and then upgrade it with the win 2000 cd?
the original win ME restore cd that came with the computer is lost. how can I get another one... or can I use one from the other computer which is win 98? Then upgrade to win 2000 from 98?
I suggest that you just go out and buy XP...you caveman...it's way better despite what anyone says.
will xp install and perform properly on a machine that came with win ME?
dduardo: I saw your pm, but my question was can I format and install win 98 from another computer to the computer I'm having probs with that came with win ME and was upgraded to win 2000
1) xp could work, but it depends on the computer's specs. I know XP runs fine on a 450Mhz computer with 128MB of ram.
2) I don't think you can do a remote install with win98.
You could do some DOS "deltree" command to delete the disk. I don't know how thorough it is though. You could also install Linux. When I recently installed Linux, it easily formatted my disk for me.
I agree with dduardo, I don't think it is possible to copy an entire OS from your computer and send the file over to another computer. Many things have to be installed and can't simply be copied.
Can you further explain what happens when you put the installation disk in?
the win 2000 disk wasn't a bootable disk the reason it wouldn't boot so I had to create startup boot floppies and then finally got to the setup mode. Instead of reformatting, it gave an option to do a repair which I did and it is working a lot better now. I downloaded and installed avg and spybot both of which would not install before. avg discovered and got rid of some viruses and now it seems to be working ok.
fyi
I think u can, most pxe enviroments are dos based, not to mention most enterprise clone software uses dos to perform any cloning of an os that can be distrubuted across a network...
however within the context I understand the question came from, you were right, I don't thnk you can mount a win98 cd across a netwrk
I wasn't asking if you could install an OS over a network or from one computer to another. My question was, "can xp be installed in a computer that came with windows me?" I now understand that it can, but needs more memory to run properly.
