Can you find all entire, doubly periodic functions on the complex plane?
  • Thread starter Thread starter Ackbach
The discussion focuses on identifying all entire doubly periodic functions on the complex plane, defined by the existence of two linearly independent periods, $\omega_0$ and $\omega_1$. The key conclusion is that the only entire doubly periodic functions are of the form $f(z) = c \cdot \text{sn}(z; k)$, where $c$ is a constant and $\text{sn}(z; k)$ is the Jacobi elliptic function. This result is rooted in the properties of complex analysis as outlined in the problem IV.5.3 from Theodore Gamelin's textbook.
  • Understanding of complex analysis concepts, particularly entire functions.
  • Familiarity with periodic functions and their properties in the complex plane.
  • Knowledge of Jacobi elliptic functions and their applications.
  • Basic grasp of linear independence in the context of complex numbers.
  • Study the properties of Jacobi elliptic functions, specifically $\text{sn}(z; k)$.
  • Explore the implications of doubly periodic functions in complex analysis.
  • Review the concept of entire functions and their classification.
  • Investigate the relationship between complex periodic functions and their applications in physics.
Mathematicians, complex analysts, and students studying advanced topics in complex analysis, particularly those interested in periodic functions and their properties.
Ackbach
MHB
Here is my first offering for the University POTW! I hope you will enjoy it.
A complex-valued function $f(z)$ on the complex plane is doubly periodic if there are two periods $\omega_0$ and $\omega_1$ of $f(z)$ that do not lie on the same line through the origin (that is, $\omega_0$ and $\omega_1$ are linearly independent over the reals, and $f(z+\omega_0) =f(z+\omega_1)=f(z)$ for all complex numbers $z$.) Find all the entire (analytic on the whole complex plane) doubly periodic functions.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
This is problem IV.5.3 in Complex Analysis, by Theodore Gamelin.
Congratulations to mathbalarka for his correct solution, which follows:
Claim : Bounded entire functions on $\Bbb C$ are constant.
Proof : Consider an entire function $f$ on $\Bbb C$ such that $|f(z)|<M$ for all $z\in \Bbb C$. By analyticity, $$f(z) = \sum_{n = 0}^\infty a_n z^n$$ where $\displaystyle 2\pi ia_n = \int_{|z|=R} \frac{f(z)}{z^{n+1}} dz$ for any positive real $R$ by definition. Thus, $$|a_n| \leq \frac1{2\pi} \int_{|z|=R} \frac{|f(z)|}{|z|^{n+1}} |dz| \leq \frac{M}{2\pi} \int_{|z|=R} \frac{|dz|}{|z|^{n+1}} = \frac{M}{2\pi R^{n+1}} \int_{|z|=R} |dz| = \frac{M}{2\pi R^{n+1}} \cdot 2 \pi R = \frac{M}{R^n}$$ Letting $R \to \infty$ results $a_n = 0$ for all $n > 0$, and using this in the series expansion above leaves us with $f(z) = a_0$, our desired conclusion. $\blacksquare$
Let $f$ be a complex entire function satisfying $f(z) = f(z + w_0) = f(z + w_1)$ for all $z \in \Bbb C$ for $\Bbb R$-linearly independent elements $w_0$, $w_1$. This implies that $f(z)$ is defined everywhere on the period parallelogram $\Lambda$ with vertices on $0, w_0, w_1$ and $w_0 + w_1$ in the complex plane. But $f$ is continuous (as it's analytic) and $\Lambda$ is a compact set in $\Bbb C$, so $f(\Lambda)$ is also compact, i.e., bounded. Extending by periodicity, $f(\Bbb C)$ is also bounded, which implies $f$ is identically constant all over $\Bbb C$ by the lemma above. Thus every doubly periodic function on $\Bbb C$ is identically constant.
Addendum (contributes nothing whatsoever to the solution of the original problem) : It should be noted that such function do exist when one lifts the condition "entire on $\Bbb C$", or rather, replaces it by "entire on $\Bbb P^1$". In that case, the function
$$\wp(z) = \frac1{z^2} + \sum_{(m, n) \in \Bbb Z^2 \setminus (0, 0)} \left [ \frac1{(z + mw_1 + n w_2)^2} - \frac1{(mw_1 + nw_2)^2} \right ]$$
is doubly periodic with periods $w_1$ and $w_2$ all over it's domain, and has two poles sitting at the vertices of the period parallelogram. In general, these functions are called elliptic functions and they arise in a major branch of mathematics focused on studying elliptic curves and modular forms.
An alternative approach would be the following:
If the function is analytic, it is continuous. Functions continuous on compact domains such as the parallelogram in question are bounded. But you can tile the entire complex plane with those parallelograms. Hence, the function is bounded everywhere. By Liouville's Theorem, such functions must be constant.
