Can you help me in this problem?
  • Thread starter Thread starter vip89
To find the dimensions of the isosceles triangle with the least area that circumscribes a circle of radius r, one can use the area formula A = 1/2 L^2 sin(θ), where L is the length of the congruent sides and θ is the vertex angle. The discussion emphasizes the importance of drawing diagrams to visualize the relationships between the triangle and the circle, particularly by identifying right triangles formed by the radius and tangent lines. A method to express the area in terms of a single variable involves using relationships between the sides and angles, specifically leveraging the right triangles created by the circle's radius. There is a suggestion to apply calculus to find the minimum area, as the original "school method" may not suffice for academic requirements. Overall, the conversation highlights the need for clarity and proper mathematical presentation when solving such problems.
vip89
Find the dimensions of the isosceles triangle of least area that circumscribes a
circle of radius r.
I think you will benefit from this equation: A= 1/2 L^2 sinθ
Have you drawn a picture? Clearly here, "L" is the side of one of the two congruent sides of the isosceles triangle and \theta is half the vertex angle. Draw the line from the center of the circle to the point where one of the congruent sides is tangent to the circle. What can you say about the triangle that forms?
I know that,but how I can make it with one variable??
First, a correction, \theta in your formula is the vertex angle, not half the vertex angle.
Half of the isosceles triangle is a right triangle with hypotenuse L and one side H= L cos(\theta/2), the altitude of the triangle, and the third side L sin(\theta/2). If you draw a line from the center of the circle to point at which the line L is tangent to the circle, that also gives a right triangle (a radius of a circle is always perpendicular to a tangent) similar to the first right triangle. The hypotenuse of this smaller right triangle is H-r and the "opposite side" has length r. That is
\frac{r}{H-r}= \frac{L sin(\theta/2)}{L}
That will allow you to write the formula in terms of the variable \theta and r, which is a constant.
That is my try
vip89 said:
That is my try
You do not really expect anybody to read this do you? I suppose you would not hand in something like this to your professor or TA or teacher or whoever (at least I strongly hope so) so why don't you bother writing it down in a tidy way if you want us to check your work?
I did it by school method
but doctor said that he want a calculus??
I didnt know how to solve by calculus?
My tip is to draw the radius of the circle to all sides, and draw also the line segments from the circles centre to each of the triangles vertexes. Now you have 6 small triangles and you can use them to find the total area of the triangle and then use the derivative to find its min value.
1. Surely the "school method" is not to write at random angles all across the paper!
2. Who is "the doctor"?
  • · Replies 59 ·
51K
