How to Prove Vector Identity Using Levi-Civita Notation?
  • Thread starter hellomynameisscottt
    Notation
9 replies · 2K views · last reply
hellomynameisscottt
OP warned about not using the homework template
I need to prove B.(Gradient . B) - B X(Gradient X B)=Del{i} [B{i}B{j} -1/2 (kroneker delta {ij} B^2]
where I have used . as the dot product, {} as subscript. Thank you!
If I write the left hand side using proper math symbols, is
\mathbf{B} (\nabla \cdot \mathbf{B}) - \mathbf{B} \times (\nabla \times \mathbf{B})
correct?
Hi Blue_leaf77,
Yes that is correct! Thank you, I am sorry I typed it so poorly I am new to Physics forums.
Then the equality in the original equation does not make sense because the left side is a vector whereas the right side is a scalar.
The right is still a vector, I have Bolded the vector quantities B.
This is essentially a proof from Jackson. But I need to show it with levi Cevita notation.
No, it's not. For instance you have ##|\mathbf{B}|^2## which is a scalar.
I have uploaded the page from Jackson it is equation (6.119) I am trying to prove, however I must use Levi Cevita notation.
  • Printed textbook page with equations (6.116) to (6.122) on electromagnetic momentum density, Maxwell stress tensor T_ab, and the divergence theorem, including [E(del . E) - E x (del x E)] written as a sum over beta of partial derivatives of E_a E_b minus one half E squared delta_ab.
I see, the left side should be ##[\mathbf{B} (\nabla \cdot \mathbf{B}) - \mathbf{B} \times (\nabla \times \mathbf{B})]_i## which is the i-th component of the vector inside the square bracket and this is a scalar. Start by writing ##\nabla\cdot \mathbf{B}## using Einstein summation notation. Anyway if you have progressed up to any point, just post it here, preferably using LaTex.
You will need to use that the i-th component of a cross product may be written as
## (\vec{A} \times \vec{B})_i = \epsilon_{ijk} A_j B_k ##
and you will need to find the expression for a triple product...hint: what is the following expression equal to?
## \sum_i \epsilon_{ijk} \epsilon_{iab} = ? ##
