Can you not separate a scalar into x and y components?
  • Thread starter Thread starter Sean1218
    Components Scalar
The discussion revolves around the concept of scalar quantities, specifically electric potential, and their relationship to vector quantities like electric fields. Participants explore the implications of separating scalars into components and question the validity of using geometric methods to analyze these quantities.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the calculation of electric potential at a point based on its distance from a charge and question why separating the potential into x and y components does not yield the same result. They also explore the differences between scalars and vectors, particularly in the context of electric fields.
There is an ongoing exploration of the relationship between scalar and vector quantities. Some participants have provided insights into the nature of electric potential and electric fields, while others express confusion about the application of the Pythagorean theorem to these concepts. The discussion is productive, with participants seeking clarification and sharing their reasoning.
Participants are grappling with the distinction between scalars and vectors, particularly in the context of electric potential and electric fields. There are references to specific calculations and the implications of using different methods to determine electric field values.
Sean1218
A scalar like electric potential.
Say I have a positive charge, and 4m to the right, and 3m up is a point P.
If I wanted to calculate the potential at point P, I'd use V=kQ/r (r=√(4^2 + 3^2)).
But I'm confused about why finding the potential at 4m to the right (the x component), and the potential at 3m above the charge (y component) and using c=√(x^2 + y^2) wouldn't give the same answer.
And I realize that this isn't independent for scalars, because doing this to find electric field would be wrong as well.
What is c? The scalar potential is itself a function of a vector if that clears up anything. Similarly, the electric field is a vector that itself is a function of a vector. i.e.
[tex]V(\vec{R})=\frac{-kq}{|\vec{R}|}[/tex]
[tex]\vec{E}(\vec{R})=\frac{kq\vec{R}}{|\vec{R}|^3}[/tex]
Well, if the electrostatic potential could have "components," then it stands to reason that any arbitrary function could. Take [itex]z = x^2 + y[/itex], for example. It is clearly true that [itex]z(4,3) = 19[/itex], but [itex]z(4,0) = 16[/itex] and [itex]z(0,3) = 3[/itex], so [itex]z(4,3) \neq (z(4,0)^2 + z(0,3)^2)^{1/2}[/itex]. Ordinary functions of space simply do not work the same way as vectors. So in a sense, it's meaningless to compare scalar quantities and vector quantities this way, because vectors are geometrical quantities which are specifically constructed to satisfy the property that you can use the Pythagorean theorem to determine their magnitude.
[tex]\vec{E}(\vec{R})=\frac{-kq\vec{R}}{|\vec{R}|^3}[/tex]
Sorry, c is just the hypotenuse so electric potential at P (or electric field at P).
Then why doesn't this method work with electric field, as it's a vector?
The answer to your question is implied by the answer to the question asked by the title of this thread:
The answer is that a scalar cannot be separated into x & y components, because a scalar is not a vector quantity. It may have a magnitude, but it does not have a direction associated with it.
So, what are you saying doesn't work? The distance to the point charge is the hypotenuse. The hypotenuse itself does have an x component and a y component. The electric potential, however, does not have any components because it just depends on the hypotenuse. The electric field, on the other hand, not only depends on the hypotenuse, but where the hypotenuse is located.
I understand now regarding electric potential and other scalars, thanks everyone.
What doesn't work is finding the x and y components of the electric field and using pythagorean theorem to find the electric field at that point. This method should give an identical answer to using E=kq/r2 where r=5 (distance between P and q), but it doesn't (for me at least).
Please show your work for this.
With a charge of 8E-6 C
x: kq/r2 = (9E9)(8E-6)/(42) = 4500
y: kq/r2 = (9E9)(8E-6)/(32) = 8000
E=sqrt(45002 + 80002)
E=9179
or:
r=5
kq/r2 = (9E9)(8E-6)/(52) = 2880 (the correct answer)
Am I just doing the first part wrong?
E=9179
or:
r=5
Right, this is not correct. The x component of the electric field vector at point P is not the same thing as the value of the electric field at x = 4, y = 0. Those are two unrelated quantities. The x component of E at point P is the magnitude of E, multiplied by the cosine of the angle between the vector and the x-axis.
  • · Replies 35 ·
