Can You Solve This Motion Problem Using a Simple Trick?
103 replies · 8K views
kuruman said:
I think that the two methods of averaging should be placed on an equal footing
As I posted, it does seem reasonable to require that (unqualified) average force = mass x (unqualified) average acceleration. Would you dispute that average acceleration means ##\frac{\Delta v}{\Delta t}##?
Other problems arise when you use vectors. ##\vec F_{avg}=\frac{\Delta\vec P}{\Delta t}## works. Try doing that with energy and displacement.
Assuming the acceleration and force is not constant but is some well behaved function over an interval, can we derive a general relationship between the two methods of averaging?
As I mentioned in post #14, it is an interesting exercise to compare the two averages for a quarter cycle of SHM. As I recall, the ratio is ##4:\pi##. I have seen this error committed in cases where SHM is a more reasonable model for the impact than is constant force.
If a body is at rest for time ##t_0## then accelerates at a for time ##t_1##, the distance based average is ##a## instead of ##a\frac{t_1}{t_0+t_1}##.
Swapping around to accelerating for time ##t_0## etc., it gives ##a\frac{t_0}{t_0+2t_1}## instead of ##a\frac{t_0}{t_0+t_1}##.
So it can give a larger or smaller result.
I would say that ##\frac{\Delta v}{\Delta t}## is indisputably time-averaged acceleration. I do not disagree with you. I have said all I have to say but, if you wish to continue this conversation, I think it should be done aside either in another thread or by PM to keep the main thread and the OP focused.
Steve4Physics said:
In what direction does this mysterious 'force due to falling' act?
So is it wrong to say “force is also created through acceleration”?
Steve4Physics said:
If it is in the same direction as mg, your equation gives:
Ffric=−(0.20×10+5)=−7N, not 7N.
No! How? mg is -ve: -mg and force due to falling or acceleration is -5 not 5. So -(-2-5)=7 N (friction force).
vela said:
Just because the knife is accelerating doesn't mean a third force is acting on the knife in addition to gravity and friction.
I want to correct you. Force is applied by the knife on the cardboard due to its acceleration caused by its weight. This force is force due to acceleration.
All that acceleration in air creates that force.
jbriggs444 said:
By "force due to falling", do you mean "total force required to explain the observed deceleration of the knife"?
No! Plus weight!
That acceleration was caused by gravitational force. It now has momentum, which is different from force.
As the knife goes through the cardboard, gravitational force still acts, as well as friction from the cardboard. There is no third force caused by the acceleration it previously underwent.
Are you saying while in air there is no force but momentum. As it collides with cardboard momentum is transferred not force. There are just two forces gravity and friction. Gravity in air and cardboard. Friction in cardboard.
No, while falling through the air there is one force, gravity. This gives the knife momentum: momentum=force x time.
The momentum gained allows it to continue descending despite the added force of friction. But it will lose momentum because the frictional force exceeds the gravitational force, leading to a net upward force.
My mistake! Yeah gravity too. Ok! So as time passes in air more and more momentum is acquired by body.( I called it force!)
So are the two forces equal at all times and because of momentum it’s going through the cardboard?
I don’t get this line.
By the way momentum is next chapter after laws of motion. Why have they given this question here or can it be understood without momentum?
So moving on friction F= -(-mg-mv/t)=-(-2+-2/t)= ?
No. While gravity was unopposed, the knife accelerated, gaining downward momentum. When it hit the cardboard, it encountered a frictional force greater than the force from gravity. The net force now being upwards, that added upward momentum, i.e. it reduced downward momentum. Eventually all the momentum is lost and the knife comes to rest.
Yes, but I mentioned it because you wrote that the downward acceleration gave the knife "force". What you were intuitively grappling with was the concept of momentum, which is different from force.
You will find it less prone to error if you always write such equations in the Newtonian form, (sum of forces) = mass * acceleration, and stick to a sign convention. In this case, the motion being vertical, you should choose to make either upwards positive for all accelerations, forces, velocities.., or downwards positive for all.
Ok.
Ok. Hence the retardation. So downward momentum starts from initial point and is there till all is lost by upward momentum. Net momentum = net force=0 . Body comes to rest.
true!
Be careful. Momentum and force do not have the same units. Saying that momentum is equal to force will never be correct. They are both zero. But they are incommensurable.
Since a force cannot equal a momentum, being dimensionally different, it is clearer to write that as momentum =0 (so no velocity), net force=0 (so no acceleration).
Note the parallel : just as acceleration is the rate of change of velocity, force is the rate of change of momentum.
Ok but please solve the problem with or without p.
You may have resolved these questions through what @haruspex has said. But since you asked me directly, here's my reply.
It is wrong. Net force (if non-zero) produces acceleration. Not the other way round.
And do not confuse 'acceleration' (units m/s²) with 'momentum' (units kg.m/s).
The 5N force is the net force as the knife passes through the cardboard. It acts upwards (which is why it slows down the knife) so has a positive value, +5N not -5N.
You do not need to invoke momentum. Just correct the equations below by including gravity.
So ##F=(200*25)/1000##
##F=5 N##
the third eqn of motion give acceleration based on the values v, u, s. The question is imagery. It’s mere algebra. But what if it were true in real life. Body falling through cardboard, the distance covered and v and u all combined should have given correct acceleration including g. It looks like while the body is traveling through cardboard, it travels a distance s and the acceleration it undergoes is in the absence of gravity.
Math wise it’s correct but physics wise it’s not, I guess!
The math, the physics and the reality all match. It is your understanding of them that is astray.
If what you know is the distance covered ##s##, the starting velocity ##u## and the ending velocity ##v## and if you have assumed that the acceleration is constant then you can indeed compute the required acceleration ##a##.
One normally accounts for this acceleration by summing the forces and computing a total acceleration: $$F_1 + F_2 = ma$$ $$a = \frac{F_1 + F_2}{m}$$You seem to want to take the forces individually, compute accelerations individually and add the accelerations. $$a = a_1 + a_2 = \frac{F_1}{m} + \frac{F_2}{m}$$So your vision is that the knife is subject to two accelerations which combine to produce the true acceleration that is actually seen?
It undergoes an acceleration. That acceleration is less than it would have been in the absence of gravity.
It matches but after separately adding the of g to a. The eqn of motions should have given correct data. Not like adding the value of g after finding a to get total acceleration.
What is the meaning of third eqn? Third eqn says final velocity of the body is v whose initial velocity is u and it undergoes a acceleration and a displacement s. Relation is ##v^2=u^2+2as##.
So it should have given us the final value of acceleration. There should have no need to add g afterwards.
In book they have done this solution which I think is not entirely correct.
It matches but after separately adding the value of g to a. The eqn of motions should have given correct data. Not like adding the value of g after finding a to get total acceleration.
You are not asked for the final value of acceleration. You are asked for the value of friction which would yield this acceleration while the knife is also subject to gravity.
The knife is subject to the force of gravity, so there is a need to model the effect of gravity.
The standard approach to the problem involves adding or subtracting forces. Not adding or subtracting accelerations. [Even though the math works either way]
I hope @haruspex will excuse me for adding this...
Gravity always acts on the knife. The knife's weight is always -2N.
The resistance force in the cardboard is +7N.
The net force on the knife in the cardboard is therefore
##F_{net} = -2N +7N = 5N##
The knife in the cardboard behaves the same as if a single +5N force acted on it.
[USER=422467]@jbriggs444[/USER] and @Steve4Physics I hope you get it in my post#81. What you are saying guys is also right.
Yeah! But why separately? 🤪
This was the original confusion in my OP. Now I guess it’s settled.
You are asked for friction. You observe the effect of friction and gravity combined. To calculate the effect of friction alone you have to somehow separate the effect of gravity from the effect of friction.
That has nothing to do with what I meant by:
Those equations being:
So F=(200∗25)/1000
F=5N
Wrong answer!
The correction needed is to be clear and consistent about what F represents. Does it represent the net force on the knife or only the force of friction?
It is kind of interesting that multiple people have told you gravity acts on the knife the entire time, but you seem to insist that gravity doesn't act on the knife once it's in the cardboard. Could you elaborate on what your thinking is here?
I wonder if it is how a student might interpret a problem if the book refers to an equation without ##g## explicitly in it as meaning gravity is not involved. But the OP has since seemed to understand that gravity is involved through the whole problem and this discussion is going in circles.
Everyone, I am silly! My mistake . The eqn of motion has given the correct value of acceleration. That is net acceleration(25). And in the back of my head I was thinking it’s not. I cannot track everything where I went wrong but you guys understand. By the way I was not switching off the gravity. Might have by Mistake somewhere!
$$Net force= friction-mg$$
$$ma= ma’-mg$$
$$a’=a+g$$
$$a’=25+10$$
$$a’=35 m/s^2$$
So,$$friction= .2*35=7 N$$
$$ma= ma’-mg$$
$$a’=a+g$$
$$a’=25+10$$
$$a’=35 m/s^2$$
Why are you dividing by ##m## only to end up multiplying by ##m##?
