Canonical transformation in classical mechanics
The discussion centers on the concept of Canonical Transformation in classical mechanics, specifically addressing the distinction between the symbols ##\delta## and ##d##. Participants clarify that ##\delta S## represents variations, while ##dS## denotes total differentials. The correct application of these concepts is essential for deriving equations related to Canonical Transformations, such as the equation involving Hamiltonian dynamics. The confusion primarily arises from notation differences in various textbooks.
  • Understanding of classical mechanics principles
  • Familiarity with Hamiltonian dynamics
  • Knowledge of differential calculus
  • Ability to interpret mathematical notation in physics
  • Study the derivation of Canonical Transformations in classical mechanics
  • Learn about Hamiltonian mechanics and its applications
  • Explore the differences between variations and total differentials in calculus
  • Review examples of Canonical Transformation problems and solutions
Students of physics, particularly those studying classical mechanics, as well as educators and researchers looking to clarify the nuances of Canonical Transformations and their mathematical foundations.
dRic2
Give the proof of the equation
$$ H' = H + \frac { \partial S } { \partial t }$$
By proceeding as follow. Leave the time t as independent variable and consider a canonical transformation in which the time appears as a parameter. Then obtain the above relation by distinguishing between ##dS## in the canonical integral and ##\delta S## in the definition of canonical transformation. In the first case time is varied, in the second case not.
Canonical integral:
$$A = \int ( \sum p_i dq_i - Hdt)$$
Definition of canonical transformation:
$$ \sum p_i \delta q_i = \sum P_i \delta Q_i + \delta S$$
I'm stuck from the beginning. I though I understood the difference between ## \delta## and ##d##, but apparently I was wrong, because I don't know how to exploit it here...
Any hint would be greatly appreciated
Thank
Ric
Are you sure you have written correct defination of Canonical Transformation?
##p_i\delta q_i -H= P_i\delta Q_i-H' + dS/dt##
In this case ,the equation is easy to derive by using chain rule to S(q,Q,t) and using linear independence of ##\dot q##and ##p##
This is the definition found in my book and it makes sense. It seems different from yours though
Ok. Then use the following:
$$\delta S= dS/dt ~dt + dS/dq ~dq + dS/dQ ~dQ$$
Now subtract ##Hdt## on both sides in your defination of Canonical Transformation
Now use the linear independence of q,Q and t
Your notation is confusion me. ##\delta S## is not ##dS##. ##\delta## is used to address variations and, since the problem asks to consider time as a parameter, you don't have to vary wrt to time. ##dS## is obviously the total differential.
Even if you meant ##dS## I don't know how to proceed.
Solved it. I was very confused by the notation of the book.
  • · Replies 21 ·
