Minimum Angular Velocity Problem
The Minimum Angular Velocity Problem involves calculating the minimum angular velocity (ωmin) required for a bob of mass 1 kg on a 1 m rope to maintain tension throughout its vertical trajectory. The solution for part (a) yields ωmin = 3.16 rad/s, derived from the equation ω = √(g/L), where g = 10 m/s². For part (b), the angular velocity is defined as ω = 2t rad/s, leading to the conclusion that the bob reaches the top position in approximately 1.58 seconds when substituting ωmin into the equation.
  • Understanding of circular motion dynamics
  • Familiarity with angular velocity and its calculations
  • Knowledge of gravitational force effects on pendulums
  • Basic algebra for solving equations
  • Study the principles of circular motion in physics
  • Learn about pendulum dynamics and energy conservation
  • Explore advanced topics in rotational motion
  • Investigate the effects of varying mass and length on pendulum behavior
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators looking for practical examples of angular motion concepts.
Clearik
First off, I want to apologize for posting more than one question. I just discovered this site, so I wanted to check my work while I am able to. Thank you again.
A massless rope of length L = 1 m is swung in the vertical plane, with a bob of mass m = 1 kg attached to its end.
(a) Calculate the minimum angular velocity ωmin that the bob of must have to keep the rope taut at every point in the trajectory.
(b) Assume now that the bob starts from the lowest position (θ = 0) at rest, and the angular velocity follows
ω = 2 x t rad s-1
Calculate the time at which the bob reaches the top position.
Fc = (m)(v2/R)
R = L
Fc = (m)(v2/L)
v = (L)(ω)
Fc = (m)((Lω)2/L)
Fc = (m)((L)2(ω)2/L)
Fc = (m)((L)(ω)2)
At the top of the circle:
(m)((L)(ω)2) = (m)(g)
((L)(ω)2) = (g)
ω = √(g/L)
(a) ω = √(10/1)
ω = 3.16 rad/s
Did I go about doing this correctly?
(b) I wasn't quite sure on how to start this part. I know that 1 radian is half a revolution. Therefore, to reach the top from the bottom (half a revolution), the time it takes t would have to be how long it takes to go one radian. Plugging in .5 yields 1 in the equation given in part b, but I don't know if this is correct.
1 radian does not equal half of one revolution.
∏ radians equals one half of one revolution.
Beyond that point, what exactly is the question in part b?
Oh, sorry, I forgot to add it, it's there now.
Hmmm, I'm not the greatest with pendulum stuff.
Perhaps, since you know that;
2 x t rad s-1 = ω = √(g/L)
You might be able to get a result from that?
So perhaps;
2 x t rad/s = 3.16 rad/s
t = 1.58 seconds?
Does that make sense?
  • · Replies 17 ·
  • · Replies 18 ·
