Can't generate multiple lines in a single [tex] block with \\?
  • Context: LaTeX
  • Thread starter Thread starter Redbelly98
    Latex Line
9 replies · 44K views
Staff Emeritus
Homework Helper
Insights Author
I can't seem to generate multiple lines within a single [ tex ][ /tex ] block. It's supposed to happen if I type \\ but it just never works for me.
Example:
[tex] f_1(x) = x \\ <br /> f_2(x) = 1-x^2[/tex]
The "f2(x)" is supposed to start on a new line.
What am I doing wrong?
Example:
Unfortunately I'm not going to be of any help to you. I've also tried this numerous times, but to the same effect.
I don't think that the \\ has ever worked on the forums, it must be some kind of bug in the software. However, one can start new lines using the flalign environment.
[tex] \begin{flalign*}<br /> f_1\left(x\right) & = & & x\\<br /> f_2\left(x\right) & = & & 1-x^2\\<br /> f_3\left(x\right) & = & & \frac{f_1}{f_2} \\<br /> & = & & \frac{x}{1-x^2}<br /> \end{flalign*}[/tex]
And the code:
Code:
\begin{flalign*}
\end{flalign*}
The * is used to suppress line enumeration. The alignment of each element is fixed to alternate between left and right as shown below
Code:
\begin{flalign*}
right & left & right & ... \\
\end{flalign*}
But you can add additional & separators to obtain the desired layout, as I have done above:
Code:
\begin{flalign*}
right & left &  & left \\
\end{flalign*}
I agree that this method is far more verbose than simply using \\ is mathmode, but it is the only work-a-round that i know of for PF. Note that the eqnarray environment does not display correctly either at PF.
Thanks Hoot. So the &'s help line up the equal signs. And if I just wanted to left-justify each line, each line would start with a &.
Code:
      \begin{flalign*}
      & f_1(x) = x \\
      & f_2(x) = 1-x^2
      \end{flalign*}
I also found this previous discussion in a locked thread:
https://www.physicsforums.com/showthread.php?t=8997&highlight=latex+line&page=19
However, in chroot's examples the code uses TWO begin and TWO end statements, eg.
\begin{equation*}
\begin{split}
So the single begin statement
\begin{flalign*}
is an improvement over that.
Thanks again!
RB
Hootenanny said:
II don't think that the \\ has ever worked on the forums
I've never known it to work in LaTeX either. (Remember that [ itex ] ... [/itex] is analogous to $ ... $, and [ tex ] ... [/tex] is analogous to \[ ... \])
Hmm, you're quite right: \\ only works in array enviroments in LaTeX :redface:
[tex] \]<br /> This is the first line.\\<br /> This is the second line.\\<br /> This is the third line.<br /> \[<br /> E=mc^2<br /> \]<br /> This is another line.<br /> \[[/tex]
Click on the rendered image to see what I did.
Maybe some [tex]\LaTeX[/tex] expert can explain what is going on.
I suspect that the forum software already places us in a [tex]\LaTeX[/tex] environment... and these \[ \] break us out of it somehow.
Sounds precisely right to me: the [tex]tag acts like \[ and by typing \], you close the latex environment.[/tex]
Now that we are using MathJax, I am revisiting how to generate multiple lines within a single LaTeX code block.
EDIT: Nevermind, I found out how to do this: https://www.physicsforums.com/showthread.php?p=261329
Also, scroll down post #1 here for multi-line examples: https://www.physicsforums.com/showthread.php?t=8997
Please disregard the following...[/color]
I just now noticed a problem with these old posts (for example Post #'s 1 and 3 above). Right now I see the LaTeX code, without the [_tex_] tags, enclosed in a box and left-right centered in the page. I have FireFox 4 and Windows 7.
Apparently MathJax doesn't like the double-backslash newline indicator, and that is preventing the code from being processed properly.
Testing:
Using same code from Post #1 again:
Same code, with double-backslash removed:
[tex] f_1(x) = x <br /> f_2(x) = 1-x^2[/tex]
So the question is, is it possible anymore to generate a new line within the same [_tex_] code block? Hootenanny's trick in Post #3 used to work -- not that I am advocating going back to the old LaTeX system.
Here:
[tex] \begin{align}<br /> a & b \\<br /> c & d<br /> \end{align}[/tex]
This one gives weird results:
[tex] \begin{multline}<br /> a b \\<br /> c d<br /> \end{multline}[/tex]
