Can't understand a step in an LU decomposition proof
1 reply · 3K views · last reply
Shirish
I'm reading about the LU decomposition on this page and cannot understand one of the final steps in the proof to the following:
Let ##A## be a ##K\times K## matrix. Then, there exists a permutation matrix ##P## such that ##PA## has an LU decomposition: $$PA=LU$$ where ##L## is a lower triangular ##K\times K## matrix and ##U## is an upper triangular ##K\times K## matrix.
I'll reproduce the proof here:
Through Gaussian elimination, ##A## can be reduced to a row-echelon (hence upper triangular) matrix ##U## via a series of ##n## elementary operations: $$E_n\bullet\ldots\bullet E_1\bullet A = U$$
Any elementary matrix ##E_i## used in Gaussian elimination is either a permutation matrix ##P_i## or a matrix ##L_i## used to add a multiple of one row to a row below it. Thus, ##L_i## will be lower triangular with non-zero diagonal ##\implies## invertible. Suppose that the first permutation matrix we encounter is in position ##j##, so that we have:
$$E_n\bullet\ldots\bullet E_{j+1}\bullet P_j\bullet L_{j-1}\bullet\ldots\bullet L_1\bullet A = U$$
Since a permutation matrix is orthogonal, ##P_j^T P_j = I## and hence
$$E_n\bullet\ldots\bullet E_{j+1}\bullet P_j\bullet L_{j-1}\bullet P_j^TP_j \bullet\ldots\bullet P_j^TP_j\bullet L_1\bullet P_j^TP_j\bullet A = U$$ or
$$E_n\bullet\ldots\bullet E_{j+1}\bullet\tilde{L}_{j-1}\bullet\ldots\bullet\tilde{L}_1\bullet P_j\bullet A = U$$
for ##i=1,\ldots,j-1##. A matrix ##L_i##, used to add ##\alpha## times the ##i##-th row to the ##s##-th row (in this case ##s>i##), can be written as a rank one update to the identity matrix: ##L_i=I+M##, where ##M## is a matrix whose entries are all zeros except ##M_{si} = \alpha##. We have that
$$\tilde{L}_i = P_jL_iP_j^T = P_j(I+M)P_j^T = P_jP_j^T + P_jMP_j^T = I+P_jMP_j^T$$
So far so good. Then we have:
The permutations performed on the rows and columns of ##M## by ##P_j## and ##P_j^T## can move the only non-zero element of ##M##, but that element remains below the main diagonal (because ##j>i##).
I can't understand this. ##M## is derived from ##L_i##, which means that ##M_{si} = L_i - I = \alpha \neq 0## and all other elements of ##M## are ##0##. Nothing has been said about ##P_j##. I'm guessing ##P_j## swaps ##j##-th row with ##r##-th row, where ##r>j##. What do the indices ##s,i## have anything to do with the indices ##r,j##?
I'd be grateful if anyone could clear this up!
Please give more details on ##P_j##. What does it look like / what exactly does it do? I'm guessing it swaps row ##j## with ##j -1## (a basic transposition going backward). Put differently what if we have
##A=
\begin{bmatrix}
\tilde{ \mathbf a_1}^T \\
\tilde{ \mathbf a_2}^T \\
\vdots\\
\tilde{ \mathbf a}_{j-1}^T \\
\tilde{ \mathbf a}_{j}^T \\
\tilde{ \mathbf a}_{j+1}^T \\
\vdots\\
\tilde{ \mathbf a}_{n-1}^T \\
\tilde{ \mathbf a}_n^T
\end{bmatrix}##
what does ##P_j \cdot A## look like? Maybe you said it and I missed it, but I didn't see that in here and it is key.
A better way to write out what is going on is as follows, using standard basis vectors:
##M = \alpha \mathbf e_s \mathbf e_i^T##
so
##P_j MP_j^T ##
##= \alpha P_j\mathbf e_s \mathbf e_i^TP_j ^T ##
##= \alpha \big(P_j \mathbf e_s\big)\big( P_j \mathbf e_i\big)^T ##
This is the point where I need you to fill in some details -- in particular what exactly does ##P_j## do? Can you write out the possible outcomes of ##P_j \mathbf e_s## and ##P_j \mathbf e_i##?
This is a bit troubling. You defined ##\alpha ## to be a scalar earlier on and somehow ##M_{si}## is a scalar (more common notation would be ##m_{si}##) but ##L_i## and ##I## are both matrices.
