Can't write calculated resulted to file in C++
  • Topic: Comp Sci
  • Thread starter Thread starter madtraveller
    C++ File
8 replies · 3K views · last reply
madtraveller
Dear physics forum,
I'm start learning C++ and I'm trying to program a space transform function for linearized convection-diffusion problem using Code:block
Everything was fine until I wrote calculated result into a file. When I run the program, some error message popped up which related to "memory could not be read" and std::ostream::sentry::sentry() in debug windows
Code:
#include <iostream>
#include <fstream> // for working with file
#include <cmath>
#include <iomanip>
#include <stdio.h>
#include <math.h>
#include <cstdlib> // for exit function
using namespace std;
// Function for calculating exponental part of transfer function //
double  expo(double dx, double celerity, double time, double dif)
    double result;
    result = -(dx - celerity * time );
    result = exp ( pow (result, 2.0) / ( 4.0 * dif * time ));
    return (result);
// Main program
int main ()
    // Creat a file to store the result
    ofstream outdata;
    outdata.open ("Result.txt", ios::out);
   if( !outdata ) {                                     // file couldn't be opened
      cerr << "Error: file could not be opened" << endl;
      exit(1);
    outdata << "OK??" << endl;
    // Declare variables
    double  PI = 3.14159,
            u  = 1.5,
            c,
            D  = 50.0,
            diffu = 0.0,
            t,
            t0 = 0.0,
            deltat = 1.0,
            deltax = 0.5;
    // Introduce number of interval
    int     n  = 50;
    // Create an array to store results of transfer function
    double  transfer[50] = {0.0};
    // Approximate c by u
    c = 5.0/3.0 * u;
    cout << "Time" << setw (21) << "Transfer function" << endl;
    // Loop for calculating transfer function
    for (int i = 1; i <= n; i++) {
        t = t0 + deltat * i;
        transfer[i] = deltax / ( 2.0 * sqrt( PI * D * t ));         // Calculate convection part
        diffu = expo(deltax, c, t, D);                              // Calculate diffusion part
        transfer[i] = transfer [i] * diffu;                         // Put 2 parts together
        cout << setw(2) << t << setw(18) << transfer[i] << endl;    // Print out results
    for (int i = 1; i <= n; ++i) {
        outdata << transfer[i] << endl;
    outdata.close();
    // Terminate the program
    return 0;
T(t,deltax) = [tex]\frac{deltax}{2\sqrt{\Pi*D*t^{3}}}*e^{-\frac{(deltax - c*t)^2}{4*D*t}[/tex]
Plz help me with this. Thank you very much for your time
Regards,
madtraveller
Arrays are index from 0 in C and C++. The valid indices into the array "transfer" are 0 to 49. You are setting and then accessing elements 1 to 50.
Your for loop runs from i = 1 to 50, and your transfer array is declared to have 50 members.
In C and C++, arrays are zero-based, which means that the elements of your array are transfer[0], transfer[1], ..., transfer[49]. Your for loop is attempting to write to transfer[50], which is outside your array. I believe that's what is causing your problem.
Change your loop as follows
Code:
for(i = 0; i < n; i++)
   // body of loop
You guys are absolutely right! This solves my problem now !
Thank you again !
Regards,
Code:
   // body of loop
Even better, use
Code:
for(i = 0; i < n; ++i)
   // body of loop
In this case use of post-increment versus pre-increment doesn't really matter. However, as soon as you start using iterators, the post-increment operator can be quite expensive compared to the pre-increment operator. In C it is fairly standard to use post-increment by default, deferring the use of pre-increment as a signal that the programmer is being tricky. In C++ it is the other way around.
Could you also tell me which one is better:
pow (a, 3) or a * a * a
Thanks
Have a nice day every1
madtraveller
well of course a*a*a will be faster since it does not have to deal with the general case in pow(). Micro optimizing like this is rarely needed and when it does it is a last move optimization that is carefully profiled. If your you really want to optimize your code here's a few things to try to accomplish:
write better algorithms,
reduce dynamic memory (when possible),
improve access to readable/writable data,
ect..
Trying to micro optimize your code at such a level will actually cause a decrease in code readability, which is a bigger con than having a minimal optimization
Unfortunately, it is a*a*a. C and C++ lack an exponentiation operator and the pow() function is a very poor substitute for it. With most compilers, pow(a,3) is equivalent to exp(3*log(a)). This is one of the two key issues that makes some Fortran programmers think that C and C++ are terrible languages for numerical programming.
