Calculate Work for 50 V Capacitor w/ 0.001 Coulombs Charge
  • Thread starter Thread starter scholio
    Capacitor Work
The problem involves calculating the work required to add an additional charge of 0.001 coulombs to each plate of a 20 microfarad capacitor charged to 50 volts. The relevant equations include capacitance (C = Q/V) and electric potential energy (U = (1/2)Q^2/C). The initial electric potential energy (U_i) is calculated as 0.025 joules, while the final potential energy (U_f) after adding the charge is 0.10 joules. The work done (W) is determined to be 0.075 joules, confirming that the assumption of doubling the charge rather than quadrupling it is correct.
  • Understanding of capacitance and its formula (C = Q/V)
  • Knowledge of electric potential energy calculation (U = (1/2)Q^2/C)
  • Familiarity with the concept of work in physics (W = ΔU)
  • Basic principles of charge distribution in capacitors
  • Study the effects of varying capacitance on electric potential energy
  • Explore the relationship between charge and voltage in capacitors
  • Learn about energy storage in capacitors and its applications
  • Investigate the implications of charge addition on capacitor behavior
Students in physics, electrical engineering, or anyone studying capacitor behavior and energy calculations in electrical circuits.
scholio
a 20 microfarad capacitor is charges to 50 volts. how much work would it require to add an additional charge of 0.001 coulombs to each plate?
capacitance C = Q/V where Q is charge, V is electric potential
electric potential energy U = (1/2)Q^2/C
work W = deltU = change in electric potential energy = U_f - U_i
i am not sure about the wording of this problem, when they say add 0.001 coulombs to EACH plate, do i quadruple the 0.001 charge for Q rather than only double it in the electric potential energy equation.
i tried only doubling the Q, but firstly:
solve for charge with C = 20*10^-6 farads, V = 50 volts use C = Q/V, solve for Q = 0.001 coulombs
solve for U_i , so Q = 0.001, C = 20*10^-6 --> U_i = 0.025 joules
solve for U_f, so Q = 0.002, C = 20*10^-6 --> U_f = 0.10 joules
solve for work W = U_f = U_i = 0.10 - 0.025 = 0.075 joules
did solve it correctly, did i make the correct assumption (double instead of quadruple)?
thanks
In a charged capacitor two plates have equal and opposite charges. If you add equal amount of charges to both plates, on one plate charges will increase and in the other plate charges will decrease.
Hi scholio,
Your answer looks correct to me. The language in the problem seems sloppy, but it should mean that the capacitor charge is increasing by 0.001 C.
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 23 ·
