Car passing two markers, kinematics question
  • Thread starter Thread starter orangegalaxies
    Car Kinematics
7 replies · 1K views
orangegalaxies
A car accelerates at 1.80m/s2 along a straight road. It passes two marks that are 28.1m apart at times t=3.75s and t=5.00s. What was the car's velocity at t=0?
d = V1t + 0.5at^2
V2 = V1 + at
i calculated the time difference between each marker, and using the first equation, i solved for V1.
i then used this V1 as V2, time as the first marker (3.75) and used the second equation to solve for V1.
is this method correct? can somebody please verify?
Delta2 said:
Yes, your method seems correct to me too.
that's a relief! would you please mind sharing your answer with me so i can verify mine?
Using the average velocity is another way to solve this problem.
PeroK said:
Or, you could use ##d = \frac 1 2 at^2## and get an equation for ##a## in terms of the difference in positions and difference in times that you are given.
14.605 m/s?
14.605 m/s?
The other approach is that average speed between the markers is ##22.48 m/s## (which is ##28.1m## in ##1.25s##), which (for constant acceleration) must equate to the speed at the middle time ##4.375s##.
Then, you can get ##v_0## from this and the acceleration.
