Can CNTs Revolutionize Exoskeleton Design?
  • Thread starter Thread starter Dummienoob
    Carbon Graphene
Carbon nanotubes (CNTs) have potential applications in exoskeleton design, particularly for artificial muscles. CNTs do not expand or contract significantly when electricity is applied; instead, their behavior is influenced by the coefficient of thermal expansion, which can be modified with electrical current. While it is feasible to produce enough CNTs for a full-body suit, using graphene as armor is currently impractical due to its properties changing when layered. A CNT-based composite is suggested as a more viable solution for armor, although it remains costly.
  • Understanding of carbon nanotube (CNT) properties and applications
  • Familiarity with graphene and its structural characteristics
  • Knowledge of thermal expansion and its relation to electrical current
  • Basic concepts of exoskeleton design and materials science
  • Research the mechanical properties of carbon nanotubes and their applications in artificial muscles
  • Explore the production methods for large-scale carbon nanotube synthesis
  • Investigate the limitations of graphene in structural applications and potential alternatives
  • Study the principles of thermal expansion in materials and its implications for nanotechnology
Engineers, materials scientists, and researchers interested in advanced materials for exoskeleton technology and nanotechnology applications.
Dummienoob
Can we make exoskeletons out of CNTs? I have a few questions
1. Do CNTs expand when electricity is applied or you have to put wax between them?
2. Can we produce enough nanotubes to make a full-body suit?
3. Is graphene suitable for an armor? Some say that when you put a elephant on a pencil and put it on a sheet of graphene, it won't break.
4500 kg - elephant's weight 0.001256 square meters - area of a pencil tip?
force pulling elphant down: 4500*9.8=44 100 N
44 100:0.001256≈35 111 465 Pa
1. I'm not sure how to answer that.
2. Depends on what you consider a body-suit. If you mean covering every area of the human body by a single layer of nanotubes, yes. But you would want much more than a single layer of CNTs for armor.
3. You're misunderstanding the quote there. It's said when you balance an elephant on a pencil and put it on graphene with the thickness of Saran Wrap, the sheet would break.
Assuming saran wrap is 10 microns thick and graphene is ~0.33 nanometers thick, you'd need ~30,000 sheets of graphene. Now there's a problem there. Graphene only has its special properties as a single layer, once you start to stack graphene, it becomes less and less special and eventually becomes graphite. So that quote would awfully hard to test, in my opinion.
tl;dr, I don't think graphene is suitable as an armor just yet, nor do I foresee it being so in the future, but I'm not an expert in armor.
I have a site that tells nothing about putting wax between the tubes: http://phys.org/news156781465.html Some say that the wax will make the muscle stronger.
But why is a single nanotube stronger than a bundle of CNTs?
For the purpose of armor, CNT based composite, I think, would be the best solution, but extremely expensive.
But not sure it's good idea to use them for artificial muscles in exosceleton. As it said by the link you provided, 'muscle' is made of aerogel based (very rarefied) oriented nanotubes, and stretching effect observed in orthogonal direction.
Do carbon nanotubes contract at different strengths depending on how much electrical current you use? This is a question that I really need answered. Thank you.
I would be surprised if applying currents to carbon nanotubes caused them to change physical shape or size.
I found out the answer to my question by asking Dr. Fadel who has a Ph.D. in nanotechnology. He said that carbon nanotubes contract/expand depending on the coefficient of thermal expansion (and you can increase this coefficient by adding more electrical current). Thank you though.
