Cardiod parametric equation problem
  • Thread starter Thread starter mahler1
    Parametric
The discussion centers on the properties of the cardioid defined by the polar equation \( r_a = a + \cos(\theta) \) for \( a > 1 \). Participants confirm that the curve is smooth if the tangent vector does not vanish, which is established through the parameterization in Cartesian coordinates as \( \Psi(\theta) = \langle f(\theta)\cos(\theta), f(\theta)\sin(\theta) \rangle \). The tangent line at the point \( (0, a) \) can be calculated using the derivatives of the parameterization. The conversation also touches on correcting a misspelled thread title.
  • Understanding of polar coordinates and their graphs
  • Familiarity with the concept of smooth curves in calculus
  • Knowledge of parameterization techniques in mathematics
  • Ability to compute derivatives and slopes in Cartesian coordinates
  • Study the properties of polar curves and their smoothness criteria
  • Learn how to derive Cartesian coordinates from polar equations
  • Explore the calculation of tangent lines to curves in both polar and Cartesian forms
  • Investigate the implications of parameterization on curve continuity and differentiability
Students studying calculus, particularly those focusing on polar coordinates and curve analysis, as well as educators looking for examples of smooth curves and parameterization techniques.
mahler1
Homework Statement .
Let ##C_a## a cardioid given in polar coordinates by ##r_a= a+cos(\theta)## with a being a parameter, and ##\theta## ##\in [0,2\Pi]##
a)Prove that, for a>1, ##C_a## is a smooth curve.
b)Calculate the tangent line to the curve ##C_a## in the cartesian coordinates point ##(x,y)=(0,a)##
My problem is I don't understand how this curve is, I mean, I googled and saw how it looks like, but I don't know the parameterization.
By the way, I accidently pressed enter, so I opened an empty thread and I couldn't check the spell in the title, it says "cardiod"", when it should be "cardioid"", does anyone know how can I correct the title?
I wouldn't worry to much about the misspelling in the title but you can ask a moderator to do it for you if it bothers you. Not sure what is bothering you about the parameterization. It is just a polar equation in the usual form ##r = f(\theta)##. Surely you have studied polar coordinates and their graphs??
Likes 1 person
For part (a), does the tangent vector vanish at all or is it continuous?
I got confused, the parameterization in polar coordinates is ##ψ(t)=(f(\theta)cos(\theta),f(\theta)sin(\theta))##
Sorry, I don't understant the question. The tangent vector doesn't vanish if the curve is smooth, I'm not sure if that what you've asked.
Exactly, if the tangent vector doesn't vanish anywhere, then it is continuous. That is the exact condition you need for the curve to be smooth.
Use either ##\theta## or ##t## for the parameter, not both. But yes, for a curve given as ##r = f(\theta)##, that is the x-y parameterization$$
\Psi(\theta) = \langle f(\theta)\cos(\theta), f(\theta)\sin(\theta)\rangle$$You can get the slope by$$
\frac{dy}{dx}= \frac{\frac{dy}{d\theta}}{\frac{dx}{d\theta}}$$
9K
