Cartesian equation for x=2sinh t, y=2cosh t
16 replies · 3K views · last reply
Fatima Hasan
Identify the particle's path by finding a Cartesian equation for it . Graph the Cartesian equation . indicate the portion of the graph traced by the particle .
##x=2sinh t## , ##y=2cosh t## , ##-\infty < t < \infty##
##cosh^2 t - sinh^2 t = 1##
##sinh t = \frac{x}{2}##
Square both sides :
##sinh^2 t = \frac{x^2}{4}## (1)
##cosh t = \frac{y}{2}##
Square both sides :
##cosh^2 t = \frac{y^2}{4}## (2)
(2) - (1) :
##\frac{y^2}{4} - \frac{x^2}{4} = 1##
put x= 0 → y=±2
Coordinate graph with x-axis labelled -4, -2, 2, 4 and two pink hyperbola branches opening up and down, with red diagonal asymptote lines through the origin and grey marks at the origin.
Is my answer correct ?
  • Coordinate graph with x-axis labelled -4, -2, 2, 4 and two pink hyperbola branches opening up and down, with red diagonal asymptote lines through the origin and grey marks at the origin.
What do you know about the possible values of ##\cosh t## for ##-\infty < t < \infty##?
The Cartesian equation forms a parbola opening up . Right ?
I just noticed something else.
$$\frac{x^2}{4} - \frac{y^2}{4} =1$$
is not correct, but I think this is a "typo".
##x=2sinh t## , ##y=2cosh2## , ##-\infty < t < \infty##
Should the second equation be ##y = 2\cosh(t)##?
yeah
I agree with @George Jones's comment in post #4.
Fatima Hasan said:
(2) - (1) :
##\frac{x^2}{4} - \frac{y^2}{4} = 1##
Take a closer look at the work I've quoted above.
##\frac{y^2}{4} - \frac{x^2}{4}## forms a hyperbola and to graph it , we should go 2 units up from center point .
##cosh ( t) ## for ##-\infty < t < \infty## is always positive .
Fatima Hasan said:
##\frac{y^2}{4} - \frac{x^2}{4} = 1## forms a hyperbola
Yes, a big hint is given by the names of the functions in the original equations. :wink::biggrin:
Mark44 said:
Yes, that looks better.
Graph of a upward-opening parabola-shaped curve on Cartesian axes, with vertex at (0, 2) and passing through (-2, 6) and (2, 6); axis ticks at -2, 2, 4, 6 on the y-axis and -2, 2 on the x-axis.
Is it correct ?
  • Graph of a upward-opening parabola-shaped curve on Cartesian axes, with vertex at (0, 2) and passing through (-2, 6) and (2, 6); axis ticks at -2, 2, 4, 6 on the y-axis and -2, 2 on the x-axis.
Fatima Hasan said:
Is it correct ?
No.
The equation ##\frac{y^2}{4} - \frac{x^2}{4} = 1## is NOT a parabola. The graph you showed appears to be the graph of ##y = x^2 + 2##, which is completely unrelated to your equation.
Graph on x and y axes from -4 to 4 showing an upper pink curve opening upward with vertex at (0, 2), and a dashed pink curve opening downward with vertex at (0, -2), with points marked at both vertices.
  • Graph on x and y axes from -4 to 4 showing an upper pink curve opening upward with vertex at (0, 2), and a dashed pink curve opening downward with vertex at (0, -2), with points marked at both vertices.
Mark44 said:
Bingo!
(Meaning, yes, that's it.)
Thanks for your help.
