Cellular respiration weird question.
  • Thread starter Thread starter alexwaylo2008
    Weird
Humans oxidize glucose through cellular respiration, releasing 686 Kcal per mole, but do not spontaneously combust due to several factors. The primary reason is the insufficient rate of oxygen uptake and the dispersed nature of glucose oxidation throughout the body. Activation energy and reaction kinetics also play crucial roles, as enzymes lower the energy of activation required for oxidation. Therefore, the body effectively manages energy extraction without the risk of combustion.
  • Understanding of cellular respiration and glucose metabolism
  • Knowledge of reaction kinetics and activation energy
  • Familiarity with the electron transport chain and its function
  • Basic principles of gas exchange and oxygen uptake in humans
  • Research the role of enzymes in metabolic pathways
  • Study the electron transport chain in detail
  • Explore the principles of reaction kinetics and activation energy
  • Investigate the physiological mechanisms of oxygen uptake in the human body
Biology students, biochemists, healthcare professionals, and anyone interested in understanding human metabolism and energy regulation.
alexwaylo2008
Humans oxidize glucose in the presence of oxygen. For each mole of glucose, 686 Kcal are realeased. This is true whether the glucose is oxidized by cellular respiration or burned in air. So why don't humans spontaneusly combust?
Biology news on Phys.org
How long do you think it takes for the human body to metabolize a mole of glucose?
Just a guess that will hopefully be corrected if wrong: If I put glucose and oxygen together in a jar, what will happen?
Better yet, we know that matches are combustible. If I put a match in a jar with oxygen, will it spontaneously combust? Well, even better yet, how long would you have to wait for it to spontaneously combust, on average?
Glucose and matches aren't so different, I suspect, besides the obvious differences...
I'm thinking of delta G, perhaps.
Oxidation needs electron separation and transfer between atoms, there thus need to be some conditions for that to happen. Oxygen is not automatically combustible or else we are burning our lungs, methinks.
686 kCal is the equivalent of walking several miles at a very brisk pace.
The rate of aerobic oxidation of glucose is slowed by a large number of factors, the primary one is the rate of oxygen uptake. What is the volume of a mole of oxygen at STP? Now account for the fact that the atmosphere is about 20% O_{2} and normal tidal volume (breath volume is less than 700ml), the exchange rate of O_{2} between alveolar air and hemoglobin is not 100%, and diffusion of oxygen is required to move oxygen into alveolar chambers.
http://faculty.washington.edu/kepeter/118/notes/pdf-set4/118gas-exchange-06.htm
In short - we can't get enough oxygen into our bodies to support a decent flame.
Plus oxidation is going on all at once in cells located all over the place in the body, not inside our stomach. The "fuel" is so spread out so far (diluted) it cannot burn anyway.
I'm dredging up an old post, so I won't feel bad about giving this guy his homework answer. I think I might disagree with your explanation to this question, not to discount the truth in that article.
This is a synopsis of the standard answer a text will give about this. I'm not sure if lack of oxygen would be a contributing factor if this other stuff weren't true, but then we'd all be really screwed. . .
It's not the lack of oxygen that prevents the reduced carbon molecules in our bodies, including glucose of course, from spontaneously combusting to a more stable, oxidized state. It's the activation energy for such a reaction that prevents it from occurring. Reaction kinetics prevents a thermodynamically favorable reaction from happening. Heat raises the energy of a molecule, which is one way to cross the energy barrier.
Also as was hinted at previously, our cells have developed a system for slowly extracting the energy from food molecules, the electron transport chain. In addition, the body carefully regulates how much energy it wants to generate, storing the rest for later as fat and glycogen. The body doesn't use heat to cross the energy barrier, it uses enzymes which actually lower the energy of activation. This is different from heat, which raises the energy of the reactant. But even if we had evolved to more rapidly oxidize food molecules, oxidizing a single molecule of glucose all at once isn't going to blow somebody up.
Drink gasoline and swallow fire. If you don't burn, tell us, okay?
Just kidding. Don't take it too personally.
XXXxx
15K
18K
  • · Replies 16 ·
  • · Replies 19 ·
