Center of mass: 2 objects in triangle system
The discussion revolves around calculating the center of mass for a system of three objects located at the corners of a triangle, with given distances between them. Participants are attempting to determine the correct formula and values to use in their calculations.
  • Mathematical reasoning, Assumption checking
  • Participants are exploring different methods to calculate the center of mass, questioning the correctness of their approaches and values used. There is discussion about setting reference points and how they affect the calculations.
Several participants have provided calculations and are verifying the accuracy of their results. There is acknowledgment of incorrect values and methods, with suggestions to revisit earlier approaches for clarity. The discussion is ongoing with multiple interpretations being explored.
Participants are working under the constraints of homework rules, which may limit the amount of detail they can share about their methods. There is also a focus on ensuring that calculations are made with respect to a defined origin.
IDKPhysics101
Three objects of different masses are located at the corners of the triangle shown in the picture. If distance a equals 4.21 m, b equals 1.55 m, and c equals 11.93 m, then what is the center of the mass (in m) of the system in the horizontal with respect to the origin?
X center of mass=6.2/6m+4.21(if set beginning of b as reference point zero then add it in the end to find respect to the origin)=5.24?
I don't have time to type my work right now. But will show work if answer is wrong to see where i went wrong.
X center of mass=6.2/6m + …
no, not 6.2, try again :smile:
well my total answer was 5.24, is that correct?
No, neither is 5.24
xcm= (2m*4.21) + (3m*5.76) +(m*7.31)
2m + 3m + m
xcm=5.5?
2m + 3m + m
xcm=5.5?
Yes, 5.5 is correct, but you really do need to go back to your original method (which was better) to see why the 6.2 was wrong :wink:
yeah, i realized that i was making 4.21 the origin or the point of reference or something to get the center of mass for just the system no regarding the origin and just adding it in at the end
Well that's correct basically and the easier way. We just don't know how you got your 6.2 in the first post.
Xcm=(2m*0)+(3m*1.55)+(m*1.55)
(2m+3m+m)
Are the 3m and the m mass at the same value of x? At least that is what you wrote there. Look at the sketch again.
  • · Replies 25 ·
  • · Replies 19 ·
