libelec
- 173
1. There are two 50 kg skaters in a friction-less horizontal surface. Both have velocities of |V|=10 m/s, in opossite directions (that is, skater 1's velocity is 10 m/s i, while skater 2's velocity is -10 m/s i). They both skate parallel to each other with a distance of 1,5m. Skater 1 has a stick, whose mass is \approx0kg and 1,5m in lenght. In one point, Skater 2 will grab the stick.
The question is to describe the position and velocity of the center of mass just before and just after the collision.
2. Because the only external forces of the skater 1-skater 2 system are each skater's weight P and normal N, I found that \sumF_{external}=0. Therefore, \vec{P} (momentum) is constant and therefore conserves. Because after one of the skaters holds the stick, both skaters will have the same speed, I assumed this is a perfectly inelastic collision. So, if skater 1's mass is m1, and skater 2's mass is m2\Rightarrow m1\vec{V1i} + m2\vec{V2i} = (m1+m2)\vec{Vf}.
I can find the position of the center of mass using \vec{r}_{CM}= (m1\vec{r1} + m2\vec{r2})/(m1+m2).
And its velocity with \vec{V}_{CM}= (m1\vec{V1} + m2\vec{V2})/(m1+m2)
Here's the thing. The problem asks to give the position of the center of mass and its velocity before and after the collision. In any case, using the conservation of momentum and the equations to find \vec{r}_{CM} and \vec{V}_{CM}, I find that the position and velocity of the center of mass are the same just before and just after the collision, and particularly, the velocity is 0 m/s.
Am I doing something wrong? Because, intuitively, in a situation like this I expect the skaters to begin a circular motion with center in the center of mass. What am I missing?
