Center of mass of a disc with a hole
The discussion revolves around calculating the moment of inertia of a disc with a hole, focusing on the application of the parallel axis theorem and the implications of mass distribution in the context of rotational dynamics.
  • Mixed
  • Participants explore the calculation of the moment of inertia by equating individual moments of inertia and applying the parallel axis theorem. Questions arise regarding the absence of terms representing the distance of the hole from the center and the implications of symmetry in the calculations.
The discussion includes attempts to clarify the calculations and the application of the parallel axis theorem. Some participants express confusion about the steps taken and seek verification of their reasoning, while others provide guidance on how to approach the problem without reaching a consensus on the final solution.
Participants note the parameters involved, including the mass and radius of the disc and the hole, and the need to consider the moment of inertia about different axes. There is an acknowledgment of the complexity introduced by the hole and its effect on the overall moment of inertia.
caspernorth
there is a similar case here :https://www.physicsforums.com/showthread.php?t=296966
so I've tried it and what i did was to equate both individual moment of inertia about z axis (and later applied parallel axis theorem) with negative mass for hole. added both these and found out Ix = M/4 [(1/2)-(r^4/R^2)]
so I think this is wrong, why isn't terms that shows how much distant the hole is located present in the equation? how can we do it. please help.
Show exactly what you did to get that result.
You need to add the moment of inertia of the disk about the z-axis and the moment of inertia of the hole (negative mass) about the z-axis. To get the moment of inertia of the hole about the z-axis, you'll need the parallel axis theorem.
Using the parallel axis theorem incorporates the distance of the hole from the center.
So Ix is symmetric but Iy isn't right?
In that case i did it entirely wrong, anyway i did it like this:
density = M/∏R^2
density = m/∏r^2
equating we get
m = (r/R)^2M
IzM = (MR^2)/2
Izm = (-mr^2)/2
substitute for -m
we get
Izm = -(Mr^4) / 2R^2
I'm stuck at this point (i guess it's parallel axes theorem now, isn't it?)
density = M/∏R^2
density = m/∏r^2
OK, you are taking M as the mass of a solid disk of radius R.
equating we get
m = (r/R)^2M
OK.
IzM = (MR^2)/2
OK.
Izm = (-mr^2)/2
This is the moment of inertia about its center of mass. But since it's not centered on the z-axis, you need the parallel axis theorem to find Izm.
substitute for -m
we get
Yes.
Ok since I can't give up I tried it once more:
By parallel axis theorem,
Iz = Icm + (M-m)y^2
(Icm = center of mass' moment of inertia, and M-m is the net mass, y is the distance between center of mass and radius of big circle)
Iz = IzM = (MR^2)/2
Center of mass turns out to be x = R+ {m.d/(M-m)} where d is distance between centers of each circle
y = R-x = {m.d/(M-m)}
So Icm = IzM - (M-m){m.d/(M-m)} ^2
Icm = (MR^2)/2 - (M-m){m.d/(M-m)} ^2
on simplifying we get,
Icm = (M/2) (Rmd)^2
please verify this, and give me the correct answer.
Iz = Icm + (M-m)y^2
Iz = IzM = (MR^2)/2
Icm = (M/2) (Rmd)^2
I'm confused as to what you are doing.
You have a solid disk of mass M (I assume that's what you want to assume) with a hole in it. (M is the mass the disk would have if it had no hole, right?)
What's the moment of inertia of the solid disk about the z-axis?
What's the moment of inertia of hole about its center? Then use the parallel axis theorem to find its moment of inertia about the z-axis.
To find the composite moment of inertia, just add those two elements together.
Well, i will make it as clear as possible.
1. what i need to find out = moment of inertia of a disc with hole.
2. M, R are parameters of disc without hole
3. -m, r are parameters of hole
Now can you show me how this can be solved. I just might make another mistake by repeating what i have already posted.
OK.
Answer the questions I asked in my last post. Do it step by step.
Let me do it another way.
I = 1/2 m r^2 + m b^2 , where b is the distance between the center of rotation and the center of mass of m.
If you cut this out of a disk of mass M and radius R, you are left with
I = 1/2 M R^2 - (1/2 m r^2 + m b^2)
what about this time
Good! :approve:
Ok, so isn't this MOI about z axis (perpendicular to the plane) I need inertia about the diameter axis. how can i do that?
Which diameter axis exactly?
You'd approach it in a similar way. Find the moment of inertia of each piece about the chosen axis then add them up.
The diameter of both, since they line up. That is the line passing through their centers.
so is the answer
I = 1/4 M R^2 - (1/4 m r^2 + m b^2)
where the 2 became 4
so is the answer
Almost. There's no need for the parallel axis theorem here, since the center of mass of the hole is already on the desired axis of rotation.
Thankyou sir, that was indeed helpful.
  • · Replies 19 ·
19K
