Where is the center of mass and black hole in this space system?
The discussion focuses on determining the center of mass of a space system containing a blue giant star, a red dwarf star, and a black hole. The blue giant has a mass of 11M and is located at coordinates (700, 0), while the red dwarf, with a mass of 0.5M, is at (800, -200). The black hole, with a mass of 2M, is also part of the system, but its location remains unknown. Participants discuss using algebra, trigonometry, and the center of mass equation to find the system's center of mass and the black hole's position. Additionally, there is a note about the importance of maintaining unique threads for different topics.
Ertosthnes
A space system consists of two visible stars, one is a blue giant with a mass of 11M and the other is a red dwarf with a mass of 0.5M. The system also has a black hole with a mass of 2M but we don't know where it is located. The blue giant is 700 gigameters away from you along the x-axis and the red dwarf is 825 gigameters away from you 14 degrees below the x axis. The blue giant is moving in the +y direction and the dwarf moves 45 degrees clockwise of the +y direction.
We're looking for the system's center of mass, and the location of the black hole.
We also assume the following about the system:
1) Orbits are approximately circular about the system's center of mass
2) All lie in the same plane
3) All orbit in the same direction (e.g., clockwise or counterclockwise)
The relevant equations are uses of algebra, trigonometry, and the center of mass equation, as far as I can tell.
So far I've mapped out the locations of the two planets; the blue giant's coordinates are (700, 0) and the red dwarf's coordinates are (800,-200). I have no idea how to continue.
If we can assume that the orbits are circular, what does this tell you about the direction of the velocity of the bodies in relation to the circular path?
The direction should be perpendicular.
I thought this post looked familiar ... and, yep, its exactly the same as this thread (less the replies). Ertosthnes, you aren't supposed to create multiple threads with the exact same topic.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 25 ·
  • · Replies 22 ·
