Central heating - available differential pressure
The discussion focuses on understanding available differential pressure in central heating systems, specifically in relation to the valve referenced in the provided catalog. To determine the available differential pressure at the end of a main supply/return pipe system, one must measure the pressure in each pipe using pressure gauges and subtract the readings. This method is essential for ensuring proper functioning and future connectivity of the system.
  • Understanding of hydraulic systems and fluid dynamics
  • Familiarity with pressure measurement techniques
  • Knowledge of central heating system components
  • Experience with installing and using pressure gauges
  • Research the installation and calibration of pressure gauges for HVAC systems
  • Learn about calculating pressure drops in piping systems
  • Explore the specifications and applications of the valve mentioned in the catalog
  • Investigate best practices for maintaining differential pressure in heating systems
HVAC engineers, plumbing professionals, and anyone involved in the design or maintenance of central heating systems will benefit from this discussion.
TSN79
I'm reading up on the use of the valve seen in the link below. On page page 5-6 there is the mentioning of available differential pressure. I struggle with understanding what that means exactly. Say I have a set of main supply/return pipes along a building, with some branches along the way connecting this and that. At the far end the main pipes are capped - being available if something needs to be connected in the future. How would I go about finding what the available differential pressure is at this end of the system?
https://imisharepointstorage.blob.c...nternational/PDF_low/STAP_DN15-50_EN_MAIN.pdf
If I've understood correctly you just measure the pressure in each pipe (eg relative to atmospheric pressure) and subtract one reading from the other.
Amplifying what @CWatters said, you have to plumb in some pressure gauges.
  • · Replies 51 ·
