Centre of mass of the observable universe
The discussion revolves around the concept of the center of mass of the observable universe, exploring whether it can be determined based on the distribution of matter and the implications of the universe's expansion. Participants examine the theoretical and observational aspects of this question, considering the implications of mass distribution and the Cosmological Principle.
  • Some participants propose that the center of mass of the observable universe is located close to the observer due to the relatively even distribution of mass.
  • Others argue that the mass distribution is not perfectly uniform, which complicates the determination of the center of mass.
  • A participant suggests that the center of mass might be outside our galaxy, based on the clustering of galaxies and their distribution.
  • Another participant questions the assumption of a perfectly homogeneous universe, noting that the actual distribution of galaxies is clustered and not uniform.
  • Some participants discuss the implications of the Cosmological Principle and how it relates to the center of mass being coincident with the observer's location.
  • There is a mention of a simple calculation estimating deviations in the center of mass based on the number of galaxies, highlighting the complexity of the actual mass distribution.
  • One participant acknowledges a previous overestimation of the uniformity of galaxy distribution, recognizing the clustering effects that may influence the center of mass calculation.
  • Another participant raises the question of whether the center of mass would be closer to the black hole at the center of the Milky Way Galaxy, suggesting local mass distribution might matter.
  • Some participants clarify that distant galaxies contribute equally to the center-of-mass calculation, regardless of their distance from the observer.
Participants express differing views on the implications of mass distribution for determining the center of mass of the observable universe. There is no consensus on whether the center of mass can be accurately defined or calculated, and multiple competing perspectives remain throughout the discussion.
The discussion highlights limitations related to assumptions about homogeneity and the effects of local mass distributions, which are not fully resolved. The complexity of galaxy clustering and its impact on calculations is also noted.
Richmonder
Ok so I have read several of the threads regarding the impossibility of determining the centre of the universe based on observations of expansion of the universe. That one seems to have been beaten to death. So this is a slightly different question. When we look at all the matter that we can currently observe in the universe, where is this system's centre of mass? Should be a pretty simple calculation no?
Space news on Phys.org
Fair enough, but based on your wording I'm not sure you got the point that was being beaten: the point isn't that we can't find the center, it is that there isn't one.
Don't even need a calculation: it's right here.
Why would the center of mass be located directly on us? Is it literally on top of us, or simply nearby (within a few million light-years)?
Yes, I accept that there isn't a centre of the universe for good reasons - the main argument that convinces me is that the universe is unbounded. And it would make sense to me that we are at the centre of the observable universe, by definition. But why would we necessarily be at the centre of mass of the observable universe? Is the mass distribution so even in every direction? I thought we had observed large scale structure.
Based on (1) the Cosmological Principle and (2) the size of the OU, I'd estimate that the center of mass is for all practical purposes conincident with the geometric center, which is of course your left eyeball when you close your right eyeball.
OK thanks for pointing me in the right direction for further reading. Much appreciated.
Because mass is distributed close to evenly throughout the universe, the center of mass of the observable universe is always located close to the observer, no matter where they are. It won't be exactly at the observer's location, because the mass distribution is not perfectly uniform, but it'll be pretty close (close in a cosmological sense, so possibly outside our galaxy).
I disagree. I refer you to post #5
That post assumes a perfectly homogeneous universe. Our universe is not perfectly homogeneous.
To do a really, really simple calculation, there are approximately ##10^{11}## galaxies in our universe. If they were distributed with a uniform random distribution (which isn't the case), then you'd expect the center of mass to be off by (very roughly) ##\sqrt{10^{11}}/10^{11}## times the diameter of the universe in each direction, for an expected deviation of (again, very roughly) 300,000 light years off from the center in each direction, or an expected magnitude of the deviation of about 500,000 light years.
So, my instinct of saying that the center might be outside our galaxy was roughly accurate. The real universe, of course, does not have galaxies distributed evenly at all: they're clustered in a very specific manner. That clustering will definitely modify this calculation, though it might go both ways: the overall uniformity of the early universe may make galaxies, on average, more evenly-distributed than the uniform random distribution case, which would make the distance smaller. But the locations of the galaxies themselves are also highly correlated, which would mean that the effective number is not ##10^{11}##, but some number much smaller than that, which would increase the expected distance.
The assumption is that the universe is perfectly homogenous on larger scales compared to the observable universe. The FRW-model is based on that. But will we ever know? I don't think so.
kimbyd said:
... So, my instinct of saying that the center might be outside our galaxy was roughly accurate. The real universe, of course, does not have galaxies distributed evenly at all: they're clustered in a very specific manner ...
I think you're right. I was overestimating the uniformity of the galaxy distribution. I mean, I KNEW it was not uniform, and roughly HOW it is not uniform, but I now think that my assumption that the huge size of the OU would smooth out the large scale distribution was overly optimistic. Thanks for correcting me on this.
Even if the OU were uniform, wouldn't the COM be closer to the BH at the center of the Milky Way Galaxy? Our local COM is closer to there than to where Earth is, no? :smile:
I don't think the local mass distribution has any impact. A galaxy one billion light years away is weighted exactly the same in the center-of-mass calculation as our own is.
The question was about the center of mass of the observable universe, so this statement doesn't apply.
  • · Replies 44 ·
  • · Replies 37 ·
  • · Replies 33 ·
9K
  • · Replies 38 ·
