Centre of percussion of a baseball bat
  • Thread starter Thread starter Clara Chung
    Baseball
7 replies · 2K views
Clara Chung
I don't know how to do the last part. How can there be no change in velocity of there is a change in angular velocity of the bat? Is the grip point acting as another axis?
If the linear velocity of the mass centre changes and the angular velocity changes then there will be a unique point at which these two cancel, leaving no change in linear velocity.
I tried to express change in angular velocity, which is
MΔv=J and Mk02 Δw = (d+1.3)J
Δv+Δw=0
so I get,
J/M + (dgrip+0.8)(d+1.3)J/ Mk02 = 0
Why can't I get the answer ?
Clara Chung said:
(d+1.3)J
Where does the 1.3 come from? What axis are you using here?
Clara Chung said:
Δv+Δw=0
You cannot add a velocity to an angular velocity.
You are trying to express the fact that a certain point does not change linear speed. How does its speed depend on the speed of the mass centre and its distance from the mass centre?
Be careful with signs.
I am using the rotational pivot. Am I right?
Does that fit with the way k0 is defined?
Thank you so much. I solved it by using the centre of mass frame^^
Very good.
For problems involving angular momentum, you should always use an axis that is either a point fixed in an inertial frame or the mass centre. Anything else can lead to a wrong result.
