Centripetal force question + other question
The discussion centers on calculating the mass of a dog on a merry-go-round and the height of an Olympic runner's center of mass during a jump. The centripetal force equation, Fc = (mv^2) / r, is used to determine the dog's mass, which is found to be 18.5 kg when correctly applying the relationship between angular speed and linear speed. Participants clarify the distinction between angular speed (1.20 rad/s) and linear speed, emphasizing the need to convert angular speed to linear speed for accurate calculations. Additionally, the discussion highlights the importance of understanding motion equations and conservation of energy for solving related problems.
  • Centripetal force calculation using Fc = (mv^2) / r
  • Understanding of angular speed and its conversion to linear speed
  • Familiarity with motion equations relating velocity, acceleration, and displacement
  • Knowledge of the conservation of energy theorem
  • Learn how to convert angular speed to linear speed in circular motion
  • Study the derivation and application of the centripetal force equation
  • Explore motion equations that relate velocity, acceleration, and displacement
  • Review the principles of conservation of energy in physics
Students studying physics, educators teaching mechanics, and anyone interested in understanding circular motion and energy conservation principles.
demode
1. A dog sits 1.50 meters from the center of a merry-go-round with an angular speed of 1.20 rad/s. If the magnitude of the force that maintains the dog's circular motion is 40.0 N, what is the dog's mass?
2. Fc = (mv^2) / r
3. We were provided with the answer "18.5" but I do NOT understand how you can get this value using the aforementioned equation. I'll demonstrate what I did:
40 * 1.50 = (1.20^2)m
60 = 1.44m
m = 41.6 kg
can someone explain to me what I'm doing wrong?
1. An olympic runner leaps over a hurdle. If the runner's initial vertical speed is 2.2 m/s, how much will the runner's center of mass be raised during the jump?
2. NO IDEA
3. Don't even know WHERE to begin. Can someone help me out?
To start off, I'd assume that for the speed, you mean 1.20 m/s, right?
For your first problem, I'll suggest rewriting the equation. Re-write it to solve for what you're looking for. Then, try it again, and see what you come up with.
For the second problem, think about what you would need to know to solve the problem, then write them down. This could get you to think of how you could actually solve the problem.
It appears you were given an angular speed of 1.2rad/s. This is NOT the same as linear speed. You must find the equation that relates angular speed to linear speed (v), then plug in that value of v into your correct equation to solve for m.
In part 2, you need to know either the motion equation that relates velocity, acceleration, and displacement, OR the conservation of energy theorem that relates kinetic and potential energies. Are you familiar with either of these equations?
  • · Replies 17 ·
