Chain rule for variable exponents
7 replies · 4K views · last reply
kolleamm
I understand that when you use the chain rule you multiply the exponent by the number in front and then reduce the power by 1. So the derivative of 2x^3 = 6x^2
I'm confused now however on how you would solve something like e^-3x, the answer turns out to be -3e^-3x
Am I missing a rule? Why isn't it -3xe^(-3x-1) ?
Thanks in advance
As you've seen, the power rule for differentiation is: ##\frac{d}{dx}x^a = ax^{a-1}##
But that's only the case when the variable is raised to an exponent that's a constant. In ##e^x## the exponent itself is the variable, making it an exponential function.
The basic rule for exponential functions is: ##\frac{d}{du}e^u = e^u\frac{d}{du}u##
For your example:
Substituting ##u## for ##-3x##, we get ##\frac{d}{du}e^u = e^u\frac{d}{du}u##
But ##\frac{d}{du}u## is ##\frac{d}{dx}-3x## which becomes ##-3##
So the original equation is: ##\frac{d}{dx}e^{-3x} = -3e^{-3x}##
You are using a rule (the power rule) where it isn't applicable.
Power rule: ##\frac d {dx} x^n = nx^{n - 1}##
In a power function, the variable is in the base. The exponent is a constant (or at least is treated as a constant as far as the differentiation is concerned.)
##e^{-3x}## is an exponential function, not a power function. Here the base is a constant, and the exponents is a variable or a variable expression.
Not quite.
##\frac{d}{dx}e^u = e^u\frac{du}{dx}##
Drakkith said:
For your example:
Correcting the above, we have ##\frac{d}{dx}e^u = e^u\frac{du}{dx} = e^{-3x} \cdot -3 = -3e^{-3x}##
Not quite.
Did you use the power rule to calculate the derivative of the exponent?
No, I used the constant multiple rule. That is, ##\frac d{dx} kx = k##, so ##\frac d{dx}(-3x) = -3##.
Ah okay , what if the exponent had an exponent? For example if it was -3x^2
Use the chain rule form of the derivative of an exponential function, which @Drakkith wrote (and I modified slightly):
##\frac d{dx}\left(e^{-3x^2}\right) = e^{-3x^2} \frac d{dx}(-3x^2) = e^{-3x^2} \cdot -6x = -6xe^{-3x^2}##
