Challenge question to the community - - Determine the inverse function of
11 replies · 2K views · last reply
checkitagain
[itex]f(x) \ = \ \dfrac{1 - \sqrt{x}}{1 + \sqrt{x}}[/itex][itex]Edit: \ \ I \ sent \ a \ PM \ to \ a \ mentor.[/itex]
Mathematics news on Phys.org
[STRIKE]Can you PM the solution to one of the mentors please?? This way we can verify that it's a challenge question and not a disguised homework problem.[/STRIKE]
OK, this is verified.
Finding √x is trivial. Just square it afterward.
Thanks for posting this. The inverse of f(x) is:
[tex] <br /> f^{-1}(x) = \frac{(1-x)^{2}}{(1+x)^{2}}<br /> [/tex]
and x>=0 to prevent singularities
If you'd like to see my work, then just ask. It's easy to show that f(f^1(x)) = x.
Edit:
But I forgot to check whether f^-1 satisfied the requirements of inverse, I'll repost later, as I made a mistake :(
[tex]\text{I don't know what you mean by/from particulars that you didn't type.}[/tex]
[tex]\text{And what about any possible restrictions on a domain?}[/tex]
DivisionByZro said:
Thanks for posting this. I didn't see the challenge here though, it's really elementary algebra. The inverse of f(x) is:
Hint: What you have typed is not a one-to-one function.
If I restrict x>=0, then my inverse is correct (I think...for now..). So I would say for x>=0, f^-1 is
[tex] f^{-1}(x) = \frac{(1-x)^{2}}{(1+x)^{2}}<br /> [/tex]
DivisionByZro said:
What you posted was not one-to-one either.
If I restrict x>=0, then my inverse is correct. So I would say for x>=0, f^-1 is
Mine (meaning the original function) is one-to-one.
Recommendation:
Graph/sketch my function and see.
Recommendation:
Yeah I had made a slight typo, I looked at the graph of a completely different function. My answer stands,
on x>=0 only.
on x>=0 only.
No to your restriction.
Hint: The range of f is the domain of f inverse, numerically speaking
(as when given in interval notation).
I must go away from the computer for a couple of hours starting now,
but I will check back for any updates.
[itex]Edit: \ \ What \ is \ the \ range \ of \ f(x) \ ?[/itex]
[itex]2nd \ edit: \ \ \ I \ \ am \ \ agreeing \ \ with \ \ Curious3141,[/itex]
[itex]but \ \ I \ \ am \ \ stating \ \ it \ \ in \ \ this \ \ edit \ \ so \ \[/itex]
[itex]that \ \ Curious3141's \ \ post \ \ will \ \ show \ \ the[/itex]
[itex]answer \ \ more \ \ recently \ \ than \ \ my \ \ own \ \ recent \ \ post.[/itex]
The inverse is:
with a domain of (-1,1] and a range of [0,∞).
Just for future reference for checkitagain and other interested readers, you can use identities for derivatives of inverse functions and generate a taylor series that corresponds to the inverse function.
The key thing to be aware of is if the derivative (of the original function) is zero which indicates a branch cut in the function which means that you have to treat each branch as an individual function in its own right (if it is to have an inverse)
