Change in scales causing change in gradient?
  • Level: High School
  • Thread starter Richie Smash
    Change Gradient
7 replies · 2K views · last reply
Richie Smash
Hello I plotted a graph of velocity against time only to realize that I needed more space on the X axis, so I changed my scale from instead of 2cm= 10 seconds to 2cm =20 seconds.
My Y axis remained constant with a scale of 2cm= 10 m/s
However, the gradient I got from the first scale was 1.15m/s2 and this even coincides with the data given.
But with my new readjusted scale to fit the page I'm getting a gradient of 2.4 m/s2.
How can this be? the graph is a straight line so the acceleration is constant according to the data given, am I plotting this wrong??
How are you calculating that gradient?
Dr Claude, I am using the triangle method and then dividing the vertical units by the horizontal units, using two poitns that are NOT given in the data but instead two points from the line of best fit I drew, which is standard practice for this level
It's somewhat hard to determine what you did wrong without seeing any work or a picture of your chart.
If you've computed the slope using algebraic means you should get the same value ie ##(y1-y0)/(x1-x0)## for your acceleration (velocity/seconds ie ##m/s^2##)
If instead you are using the grids on your graph paper then of course you'll get something different unless you adjust for the x length of the grid element.
As an example, if you computed it using ##(y1-y0)## in centimeters over ##(x1-x0)## in centimeters then that is wrong.
Whereas if you computed it ##( (y1-y0).in.cm) * (10m/s.per.cm) )## over ##( ((x1-x0).in.cm) * (20 seconds.per.cm))##
Then my guess is that you are not calculating the units correctly.
Can you post the plots you did? It may help in figuring where you are going wrong.
Ok here are my images with the scales represented above and the data presented to plot orginally...
However I realized what I did wrong... I simply forgot to convert thehorizontal units in my new graph the second picture, to suit...it was just one tiny mistake... how DO I avoid these? The test I'm studying for specifically wants me to do the triangle method, bigger than half the line, etc.
BUt there's not much time and I somtimes I just make silly errors, now I feel dumb sorry for this silly post
  • Hand-drawn straight line graph on blue grid paper, plotted from the origin up to the point (4.6, 2), with a dashed right-angle triangle drawn beneath the line. The horizontal axis is labelled 0, 0.5, 1.0, 1.5, 2.0, 2.5 and the vertical axis 0 to 20 in steps of 5 with the top labelled 2.
  • Hand-drawn straight-line graph on squared graph paper, photographed at an angle, with a dashed right-angle triangle drawn beneath the line; axis labels are partly legible and rotated.
  • Photo of a printed Table 1 with two columns: Velocity, V/ms-1 and Time, t/s, listing velocity against time from 0.0 to 69.0 m/s and 0.0 to 60.0 s in 10-second steps.
This is NOT a silly post. We all learn from our mistakes.
The most humbling thing is that we learn we make mistakes. The second thing is in reconstructing our reasoning we might determine why we made the mistake.
To be fair, you caught your mistake and that is a very hopeful sign that you're really grasping the subject. This mistake will stick with you forever and I'm sure you won't make this same mistake twice. (fingers crossed). You can even pass it on to your kids with some sagely advice.
Our mistakes teach us so much and eventually we get to teach them to others.
