Characterisitics of a Parabolic PDE
  • Context: Graduate
  • Thread starter Thread starter Tohiko
    Pde
The discussion centers around finding the characteristics of a second-order, nonlinear, multidimensional parabolic partial differential equation (PDE). Participants explore methods for generalizing known techniques from one-dimensional cases to this more complex scenario, focusing on the mathematical formulation and the necessary conditions for determining characteristics.
  • One participant seeks guidance on finding characteristics for a specific parabolic PDE involving multiple independent variables.
  • Another participant suggests starting with the definition of characteristics related to the non-uniqueness of second-order derivatives, leading to a determinant that must be solved.
  • A participant mentions a reference book that discusses high-dimensional systems and quadratic forms relevant to the topic.
  • There is a clarification that parabolic PDEs have only one independent characteristic, unlike hyperbolic PDEs which have two.
  • One participant describes their approach of constructing a matrix from second-order derivatives and expresses confusion about the number of rows needed for the matrix.
  • Another participant provides an example of differentiating first derivatives with respect to a characteristic variable, illustrating how to set up the determinant for finding characteristics.
  • A participant reflects on their understanding of independent equations in the context of a three-dimensional PDE and attempts to apply similar reasoning to their five-variable case, hypothesizing about the number of independent equations.
Participants generally agree on the foundational concepts of characteristics in PDEs but express differing views on the specific methods and formulations needed for the multidimensional parabolic case. The discussion remains unresolved regarding the exact formulation and independence of equations in the matrix setup.
Participants note limitations in their understanding and access to resources, which may affect their ability to fully resolve the problem. There is also uncertainty regarding the independence of equations derived from the PDE.
Tohiko
Greetings,
I want to find the characteristics of the following parabolic PDE
u_t + v u_x + w u_y + a(t, x,y,v,w, u) u_v + b(t, x,y,v,w, u) u_w - u_{vv} - u_{ww} = c(t,x,y,v,w,u)
Where u=u(t,x,y,v,w)
I know how to find the characteristics of a 2nd-order one-dimensional PDE. I also know how to find the Riemann invariants of a hyperbolic multidimensional PDE.
But how do I find the characteristics of a 2nd-order, nonlinear, multidimensional, parabolic PDE?
Any pointers or references are much appreciated.
Thanks
I am unsure what exactly you mean here, you can if you wish find the standard form for your equation by finding the characteristic directions in your second order system.
From what I can gather about your system you have one variable u which is a function of t,x,y,v,w Is this the case?
That's exactly the case
And as you said, what I want to find are the characteristic directions for this PDE.
It's just that I don't know how to generalize what I already know in 1D case to this case.
Characteristics are generally defined as where the second order derivatives are not uniquely defined, so you could start with this idea, you will get a 5x5 determinant that when expanded would give you a polynomial that you would have to solve.
Thank you hunt_mat,
I think I understand your idea. I will try it out and see what I'd get.
Thank you again
I got this from the book applied partial differential equation be Ockendon et al. They even have some discussion about high dimensional systems at the end of chapter 3. It comes down to looking at quadratic forms.
A hyperbolic pde has two independent characteristics.
A parabolic pde has only one.
An ellipitic pde has none.
for a system with two variables, however this is not the case in question.
I'm trying out this idea. And I'm a little perplexed
I don't have access to the book that you mentioned but I'm following these notes
http://www2.imperial.ac.uk/~jdg/AE2MAPDE.PDF
Section 2.1, pages 8 and 9
Following similar ideas to what these notes have I wrote the differentials: dt, dx, dy, dv, dw
And set up a 6x15 matrix multiplying a vector of 2nd order derivatives (mixed and otherwise). But then I don't know what other rows to add to the matrix.
You said that I should obtain a 5x5 determinant, but frankly I don't how I would obtain it.
My mistake, it should be a 15x15 matrix. Let me give an example with 2 variables. Differentiate the first derivative, say \partial_{x}u with respect to the characteristic variable to obtain:
\left( \frac{\partial u}{\partial x}\right) '(s)=\frac{\partial^{2}u}{\partial x^{2}}\dot{x} +\frac{\partial^{2}u}{\partial x\partial y}\dot{y}
Likewise:
\left( \frac{\partial u}{\partial y}\right) '(s)=\frac{\partial^{2}u}{\partial x\partial y}\dot{x} +\frac{\partial^{2}u}{\partial y^{2}}\dot{y}
Along with the differential equation itself:
a\frac{\partial^{2}u}{\partial x^{2}}+b\frac{\partial^{2}u}{\partial x\partial y}+c\frac{\partial^{2}u}{\partial y^{2}}=d
Now as we sais that the definition of characteristics were when the second order derivative were not unique, that you mean that the determinant:
\left| \begin{array}{ccc}<br /> a & b & c \\<br /> \dot{x} & \dot{y} & 0 \\<br /> 0 & \dot{x} & \dot{y}<br /> \end{array}\right| =0
From here one obtains the quadratic necessary to find the characteristics. Do you this for your system.
That's what I did, but as I said I don't have enough rows.
I differentiated dt,dx,dy,dv and dw with respect to the characteristic variable s. These gave me 5 rows. Plus one row from the differential equation itself. So I obtain 6 rows of the 15x15 matrix.
But what about the other 9 rows?
I think I understand what I'm missing. I read a paper about finding the characteristics of a 3D PDE here (http://aerade.cranfield.ac.uk/ara/arc/rm/2615.pdf ).
In there since the PDE is a function of 3 variables the characteristics would be a function of 2 variables \alpha and \beta. Then they differentiate the differentials dx1, dx2 and dx3 wrt \alpha and \beta obtaining 6 equations of which 5 are independent (since the PDE defines a relation between 2nd order differentials). These 5 equations along with the original PDE give a 6x6 matrix whose determinant should equal 0.
In my case since I have 5 independent variables I'm guessing the characteristics would be a function of 4 variables p,q,r and s
Then I differentiate the differentials dt,dx,dy,dv,dw wrt to p,q,r and s obtaining 20 equations. Of which I'm guessing only 14 are independent. These 14 equations along with the original PDE give another PDE of the characteristic surfaces.
Does this sound right? If it is, do you know why only 14 of the equations are independent?
