Parabolic pde with additional term
  • Thread starter Thread starter idraftscience
    Pde Term
2 replies · 1K views · last reply
idraftscience
Solve
[itex]\frac{\partial v}{\partial t} = k\frac{\partial^2 v}{\partial x^2} - v[/itex]
[itex]0\leq x \leq L[/itex]
[itex]t > 0[/itex]
[itex]v(x,0) = f(x), v(0,t)=0, \frac{\partial v}{\partial x}(L,t) = -v(L,t)[/itex]
I've already attempted to solve this using separation of variables, but I'm not sure if that is a valid approach as the equation is not homogeneous (?) due to the v(x,0) = f(x) term. I've also attempted using green's theorem but I keep getting stuck, though this may be due to a math error. Can anyone give me any insight as to where I may be going wrong?
If you can separate the variables, it will produce a valid solution. The question is whether all solutions can be achieved that way. The critical issue is whether a linear sum of two solutions produces a solution. If so, arbitrary solutions can be represented as an infinite sum of solutions obtained by separation of variables.
Does this equation have that property?
idraftscience said:
Solve
[itex]t > 0[/itex]
The equation is homogeneous and linear, so separation of variables should work. (Not being homogeneous is in any case not fatal to separation of variables, you just have to use a "particular integral plus complementary functions" approach; not being linear is fatal.)
The eigenfunctions are [tex] v(x,t) = T(t)X(x) = T(t)\sin(\lambda x)[/tex] where the possible values of [itex]\lambda[/itex] are determined by the condition that [tex] X(L) + X'(L) = 0,[/tex] and since you're given arbitrary initial data the fact that you can't find [itex]\lambda[/itex] analytically is not important. Sturm-Liouville theory tells you that the resulting eigenfunctions will be orthogonal with respect to the inner product [tex] \int_0^L f(x)g(x)\,dx[/tex] as usual. You can find [itex]\|X\|^2 = \int_0^L X(x)^2\,dx[/itex] in terms of [itex]L[/itex] and [itex]\lambda[/itex], but obviously if you can't find [itex]\lambda[/itex] analytically you can't find [itex]\|X\|^2[/itex] analytically.
