Electric Field Inside a Charged Insulating Sphere
The problem involves determining the electric field inside a charged insulating spherical shell, specifically at a distance from the center where the distance is less than the inner radius of the shell. The subject area is electrostatics, focusing on Gauss' Law and electric fields in relation to charge distributions.
  • The original poster attempts to understand why the electric field is zero inside the cavity of the charged insulating shell, referencing Gauss' Law. Some participants question the implications of having no enclosed charge within the Gaussian surface and explore the reasoning behind the symmetry of the electric field.
The discussion is actively exploring the reasoning behind the electric field being zero in the cavity. Participants are engaging with the concepts of charge distribution and symmetry, with some guidance provided regarding the application of Gauss' Law and the implications of symmetry in electric fields.
Participants are considering the assumptions related to the charge distribution and the nature of the insulating material, as well as the implications of symmetry in determining the electric field within the cavity.
yango_17
A charged spherical insulating shell has inner radius a and outer radius b. The charge density on the shell is ρ.
What is the magnitude of the E-field at a distance r away from the center of the shell where r < a?
Gauss' Law
I read through the Gauss' law chapter in my textbook, and it stated that the internal electric field of such a charged insulator is zero. Therefore, I know the answer is 0 but I do not know why. Any explanation as to why this answer is correct would be appreciated. Thanks.
Well, Gauss's law states that: [tex]\oint \mathbf{E} \cdot \ d \mathbf{A} = \frac{Q_{enc}}{\epsilon_0}[/tex] What is the enclosed charge if you use a Gaussian surface inside the cavity?
0. Is it because there is no charge in the cavity?
Correct. If you imagine your Gaussian surface to be a sphere inside the cavity centered at the center of the larger sphere, no charge is inside (so Qenc = 0). All the charge is in the insulated sphere in this problem.
Now, the integral being equal to 0 is not a necessary condition to declare that the electric field is 0. For instance, [itex]\int _{-1} ^1 x \ dx = 0[/itex], so this is not enough to declare that there is no electric field inside.
Edit: changing the argument because I saw a flaw in it. Simply put: by symmetry, the electric field should cancel out everywhere inside the sphere.
If it didn't cancel out, which direction would get precedence? Why should any direction of a perfectly symmetrical sphere get the privilege of having the electric field not cancel out?
  • · Replies 17 ·
  • · Replies 19 ·
