Charges on an Outer & Inner Shell w/ -5.0E-6C Center
The discussion revolves around the electrostatics of a spherical shell with a central charge of -5.0E-6 C. Participants are exploring the distribution of charges on the inner and outer surfaces of the shell, considering whether the shell is conductive and how charges interact in this context.
  • Participants are questioning the nature of the shell material and its implications for charge distribution. There are discussions about induced charges on the inner surface and the overall neutrality of the system. Some participants are attempting to deduce the charges on the inner and outer surfaces based on the central charge.
The discussion is active, with various interpretations being explored regarding the charge distribution. Some participants are offering insights into the behavior of induced charges, while others are questioning the assumptions made about the system's neutrality and charge balance.
There is uncertainty regarding whether the shell is conductive, which affects the reasoning about induced charges. The problem does not specify the nature of the shell, leading to differing conclusions among participants.
mollyanne15
A shell with a charge of -5.0E-6 C at the center. What will the charge be on the inner surface of the shell? The outer?
Is the shell made of a conducting material?
It doesn't say. The first part of the question says, "A thin spherical shell of radius 15.0cm with total charge of 33.0E-6 C distributed uniformly on its surface."
If there was a ball of charge of -5.0E-6...
I presume it's a conductor, since the charge on the inner surface changes with the introduction of charge in the centre. So, what do you know about induced charges on the inside surface of a conductor?
I would think that the charge on the inner shell would be +5E-6, so would that make the outer 0 to keep an overall neutral charge on the shell?
If there's an induced charge of +q on the inside, where's the -q gone, to keep the shell have overall zero charge? How can a charge of 0 on the outer surface keep it neutral, as you've written?
Because the charge in the center is (-), that would make the charge closest to it (inner) opposite in sign (+5E-6) leaving the outer surface zero.
The conductor was initially neutral. You've put -q at the centre, and saying that now there's +q on the inner surface and 0 on the outer surface, which makes the system overall neutral. How can that be, when you've introduced some -q in the system?
If +q is induced on the inner surface, there must be a -q somewhere to balance it.
So would the outer surface also be +5E-6?
-5E-6; -q at the centre, +q on the inner surface, and -q on the outer surface.
14K
