Check my proof for a problem in the attachment
  • Thread starter PatternSeeker
    Proof
PatternSeeker
Hi,
I am working on a proof . Could you kindly check my work in the attachment?
Am I addressing the problem correctly? Also, am I missing any steps?
The problem is stated in the attachment. My work in progress and a relevant diagram are also included.
Thanks in advance for your help.
  • Handwritten worked solution with a geometry diagram: a right triangle with vertices A, B, C and a point F, angles alpha, beta, theta and gamma marked, and numbered algebra steps (1) to (7) relating sin beta, BF, CB and cos(alpha + beta).
Your "proof" doesn't mean anything. You list 7 fairly straight forward statements and then add the conclusion at the end. But it doesn't follow from the previous statement.
In fact, exactly what is it you are trying to prove? "Show that angle [itex]\beta[/itex] will approximate [itex]1/(AB)^2[/itex] as AB increases in length". Are you saying that in the limit as AB goes to infinity? If so then [itex]1/(AB)^2[/itex] will go to 0. Is that what you are saying? That the angle goes to 0? Your "proof" cannot be right because it says nothing about AB "increasing". It is purely static.
Hi,
Thank you for answering. I see your point. A proof should reflect an increase in the length of "AB". What I would like to show is that angle Beta decreases (towards zero) at a quadratic rate. Apparently the decrease in that angle should be inversely proportional to (AB)^2. Any further suggestions will be appreciated.
Something is going wrong with your proof. When AB grows, you have [itex]\cos(\alpha + \beta) \rightarrow 1 + \mathcal{O}(\beta)[/itex], [itex]\sin^2(\beta) \rightarrow \beta^2[/itex], so you wouldn't get the scaling you're asked for. This problem is very easy to do using Taylor series: all you need to do is to write [itex]\beta = \theta-\alpha[/itex]and then expand the angles into series -- you should get something like [itex]\beta \sim \frac{AC}{AB} - \frac{AC}{AF}[/itex]. Perhaps there is some geometric way of getting a similar relation?
