Checking an electromagnetic theory solution
43 replies · 6K views
PeroK said:
Just to say that I'm getting an "unsolvable" cubic equation in ##\tan \theta##. Does the question expect an exact solution?
It is a cubic relation.
Answer provided that I just found at the back of the book $$ \tan^3 \theta ( 1+ \tan^2 \theta ) = \dfrac{q^2}{8 \pi \epsilon_0 mgl^2} $$
Of course this means nothing to me. I am supposing that this is a related rates problem and that I need more than what I think I have so far in terms of the tangent.
First, generate the force balancing equations for ##T, F## and ##mg##.
Need to go to work now, but will come back to this with this approach.
Thank you so much!
I get $$ \tan \theta (\sin^2 \theta ) = \dfrac{q^2}{8 \pi \epsilon_0 mgl^2} $$which is the same as $$\frac{ \tan^3 \theta}{1+ \tan^2 \theta} = \dfrac{q^2}{8 \pi \epsilon_0 mgl^2} $$
You are right, I missed the "/" it is the second.
I was able to reach your calculations. If you're feeling generous, give this a look?
  1. $$ F_c = \dfrac{1}{4 \pi \epsilon_0 } \dfrac{2q^2}{r^2} $$
  2. $$ \tau_x = F_c $$ (stability)
  3. $$ \tan \theta = \dfrac{\tau_x }{mg} $$
  4. $$ r = 2 l \sin \theta $$
  5. $$ q = 2q_{1}^{2} $$ (charge is twice the other of equal mass)
Substituting 4 into 1 yields,
$$ F_c = \dfrac{1}{4 \pi \epsilon_0 } \dfrac{2q^2}{(l \sin \theta)^2} $$
$$ F_c = \dfrac{q^2}{8 \pi \epsilon_0 l^2 \sin^2 \theta}$$And Substituting 2 into 3 yields,
$$ \tan \theta = \dfrac{F_c}{mg} $$
Due to the stability condition. After simplification and arithmetic,
$$ \dfrac{\dfrac{q^2}{8 \pi \epsilon_0 l^2 \sin^2 \theta} }{mg} = \tan \theta $$
$$ \dfrac{q^2}{8 \pi \epsilon_0 mg l^2 \sin^2 \theta} = \tan \theta $$
$$ \dfrac{q^2}{8 \pi \epsilon_0 mg l^2} = \tan \theta \sin^2 \theta$$
Usiia said:
$$ r = l \sin \theta $$
This can't be right. ##r = 2l \sin \theta##.
Usiia said:
$$ F_c = \dfrac{2q^2}{4 \pi \epsilon_0 } \dfrac{2q^2}{(l \sin \theta)^2} $$
You have an extra factor of ##2q^2## there. The next line is correct, but doesn't follow from that:
You got the right answer in the end, but there are still some mistakes.
I edited it, equations needed pruning and it missed my eye. Number 4 needed to be as you mentioned.
Okay, but it's still wrong in some of your equations:
@PeroK Thank you so much for your continued help. I haven't done this in many many years and it's slowly coming back :)
You are correct, I will try to take this into a latex editor and look it over. It's very difficult making sure it's right on the forum just using preview.
I am trying to copy this from my paper, but not uploading any more scratch work by hand.
I believe this should be correct completely with the substitutions.
  5. $$ q_1q_2 = 2q_{1}^{2} $$ (charge is twice the other of equal mass)
$$ F_c = \dfrac{1}{4 \pi \epsilon_0 } \dfrac{2q^2}{(2 l \sin \theta)^2} $$
