Checking the Efficiency of Function(int n) - Let's Count Key++ Executions!
  • Context:
  • Thread starter Thread starter evinda
    Count Efficiency
44 replies · 8K views
evinda
MHB
Hello! (Wave)
I have the following function:
Code:
Function(int n){
  int key,j,k;
  for (j=2; j<=5n^3; j+=5){
        for (k=j; k<=3n^(2/3); k+=3){
             key++;
I want to find how many times the command
Code:
key++
is executed.
That's what I thought (Thinking) :
The outer for loop is executed $ \displaystyle{ \frac{5n^3-2+1}{5}=\frac{5n^3-1}{5}}$ times, the nested for loop is executed $ \displaystyle{ \frac{1}{3} \cdot \sum_{j=2}^{3n^{\frac{2}{3}}} 1 =\frac{1}{3} \cdot \sum_{j=1}^{3n^{\frac{2}{3}}} 1 -\frac{1}{3}=\frac{1}{3} \cdot 3n^{\frac{2}{3}}-\frac{1}{3}= n^{\frac{2}{3}}-\frac{1}{3} }$ times.
Therefore, the command is executed $\displaystyle{ \frac{5n^3-1}{5} \cdot \left ( n^{\frac{2}{3}}-\frac{1}{3} \right ) }$ times.
Could you tell me if it is right or if I have done something wrong? (Sweating)
evinda said:
Hello! (Wave)
Code:
Function(int n){
  int key,j,k;
             key++;
Code:
key++
is executed.
Hey! (Malthe)
Let's see... suppose we substitute $n=1$... (Thinking)
I like Serena said:
Hey! (Malthe)
Then, the command is executed once, but according to my result, it is executed $\frac{8}{15}$ times.. :eek: What have I done wrong? (Thinking)
Let's start with the outer loop.
Or rather, let's start with an intermezzo. (Emo)
Suppose you are walking along a road that is 100 meters long.
And suppose every meter there is a marker.
How many markers are there? (Thinking)
And what if the road is 99.8 meters? (Thinking)
There are $100$ markers, right? (Wasntme)
In this case, there are $99$ markers, right? (Thinking)
Eek. :eek:
Suppose the road is 2 meters long... how many markers? :rolleyes:
I like Serena said:
Eek. :eek:
Aren't there two markers? One at the first meter and one at the second one?
Or am I wrong? (Thinking) (Blush)
https://www.physicsforums.com/attachments/3330
Doesn't your picture show 3 markers? (Wasntme)
So, is there also a marker at the beginning of the road, before we have one meter? (Thinking)
Yep.
One at the beginning of the road, and one every meter, including one at the end of the road. (Wasntme)
I like Serena said:
Yep.
So, have I done a mistake at the limits of the sum? (Thinking)
Before we go back to the limits of the sum...
Suppose the road is $x$ meters long and has markers at every $d$ meters.
How many markers? (Wondering)
Is it maybe $\displaystyle{ \lfloor \frac{x}{d} \rfloor}+1$ ? (Thinking)
Yes! (Nod)
Now let's get back to the outer loop.
How many iterations? (Wasntme)
I like Serena said:
Yes! (Nod)
How could we explain that it is like that? (Thinking)
Are there then $\lfloor \frac{5n^3-2}{5} \rfloor +1$ iterations? (Thinking)
We can explain it by using the road-with-markers-principle. (Nerd)
If $x$ is a multiple of $d$, there are $\frac x d + 1$ markers.
If $x$ is not a multiple of $d$, we have to round $\frac x d$ down for a total of $\left\lfloor\frac x d\right\rfloor + 1$ markers.
Yes.
Can you simplify that expression? (Wondering)
A ok.. Is this principle known? (Wasntme)
I like Serena said:
Yes.
Is it maybe like that?
$$\lfloor \frac{5n^3-2}{5} \rfloor +1=\lfloor n^3-\frac{2}{5}\rfloor+1, \text{ and since } \frac{2}{5}<1, \lfloor n^3-\frac{2}{5}\rfloor+1=\lfloor n^3\rfloor+1$$
The principle is known, although I'm not sure if it has a name.
Suppose $n=1$...? (Wondering)
evinda said:
It is equal to: $1$, so it cannot be like that.. How could I simplify it then? (Thinking)
Let's take another look at $\left\lfloor n^3-\frac{2}{5}\right\rfloor + 1$.
$n^3$ is an integer.
Since we subtract $\frac{2}{5}$, and then round down, the result will always be 1 less.
And then we add 1 again... (Thinking)
So, you mean that $ \displaystyle{ \left\lfloor n^3-\frac{2}{5}\right\rfloor=\left\lfloor n^3-1\right\rfloor }$ ?
Why is it like that? (Sweating)
Yes, because this is what rounding down means. (Nerd)
For instance, for $n=1$ we have:
$$\left\lfloor 1-\frac{2}{5}\right\rfloor=\left\lfloor \frac{3}{5}\right\rfloor = 0$$
More generally, $\left\lfloor n^3-\frac{2}{5}\right\rfloor$ is always greater than the integer $n^3-1$ and smaller than $n^3$.
Therefore rounding down yields $n^3-1$. (Wasntme)
Is there an identity that we could use, to show it? (Thinking) :confused:
The floor function is defined as:
$$\lfloor x \rfloor=\max\, \{m\in\mathbb{Z}\mid m\le x\}$$
Now note that $n^3 -1 \le n^3 - \frac 25$ and that $n^3 > n^3 - \frac 25$.
So $n^3 -1$ is the largest integer less or equal than the number we're rounding down. (Wasntme)
A ok.. I understand! (Nerd)
Could you also explain me why it is:
$$ \lfloor \frac{5n^3-2}{5} \rfloor +1$$
and not:
$$\lfloor \frac{5n^3-2+1}{5}\rfloor $$
? (Thinking)
and not:
? (Thinking)
Because however long the road is, there will always be one marker at the beginning of the road.
We calculate how many markers come after by taking the length of the road, dividing by the distance between markers, and rounding down. (Wasntme)
So, at this algorithm, do we know, for sure, that the first for loop is executed for $j=2$ and we want to calculate how many times it will be executed for $j=7$ till $j=5n^3$ ? (Thinking)
There is an exception.
That is if $5n^3$ would be smaller than $2$ (which is not the case here).
Then the loop would not be executed at all.
If that would be the case, the formula would come out as zero or negative. (Mmm)
So, in our case, is it like that because of that what I wrote at post #26 ? (Thinking)
In which case does the formula come out negative? (Thinking)
Yes. (Nod)
If you pick for instance $n=-1$. (Rain)
I like Serena said:
Yes. (Nod)
A ok.. (Nod) And is the inner loop executed $\displaystyle{ \lfloor \frac{3n^{\frac{2}{3}}-j}{3} \rfloor+1 }$ times, each time ? (Thinking) (Wasntme)
