Checking the Efficiency of Function(int n) - Let's Count Key++ Executions!
  • Topic:
  • Thread starter Thread starter evinda
    Count Efficiency
44 replies · 8K views
evinda said:
A ok.. (Nod) And is the inner loop executed $\displaystyle{ \lfloor \frac{3n^{\frac{2}{3}}-j}{3} \rfloor+1 }$ times, each time ? (Thinking) (Wasntme)
Yes. (Happy)
And before we go on, how many times is the outer loop executed? (Wondering)
I like Serena said:
Yes. (Happy)
Isn't it executed $\lfloor n^3-1 \rfloor+1$ times? (Thinking) (Thinking)
Yes... but you can simplify it further... (Wasntme)
Is it :
$$ \lfloor n^3-\frac{2}{5}\rfloor = \lfloor n^3-1\rfloor$$
or
$$\lfloor n^3-\frac{2}{5}\rfloor= n^3-1$$
? (Thinking)
evinda said:
Is it :
or
? (Thinking)
Those are the same! (Wasntme)
If you take the floor of an integer, it's just that integer.
A ok! (Nod) So, the outer loop is executed $n^3-1$ times, right?
The inner loop is executed $\displaystyle{ \lfloor n^{\frac{2}{3}}- \frac{j}{3} \rfloor+1 }$ times..But.. how can we simplify it, now that $j$ is not a constant? (Thinking)
Nope.
Can you check the formula you had again? (Angel)
The outer loop is executed $\displaystyle{ \lfloor n^{\frac{2}{3}}- \frac{j}{3} \rfloor+1 }$ times..But.. how can we simplify it, now that $j$ is not a constant? (Thinking)
I guess you mean the inner loop. :rolleyes:
Let's start with the first time the loop is executed.
That means $j=2$.
How many times does that make? (Wondering)
And how many times during the second time when $j=7$?
I like Serena said:
Nope.
Oh, sorry! It is $n^3$, right? (Blush)
(Nod) (Blush)
That means $j=2$.
The first time, it is executed $\displaystyle{ \lfloor n^{\frac{2}{3}}- \frac{2}{3} \rfloor+1 }=n^{\frac{2}{3}}-1+1=n^{\frac{2}{3}}$ times, when $j=7$, it is executed $\displaystyle{ \lfloor n^{\frac{2}{3}}- \frac{7}{3} \rfloor+1 = n^{\frac{2}{3}}-3+1=n^{\frac{2}{3}}-2}$ times..
Or am I wrong? (Thinking)
Yep. (Nod)
Previously, we used that $n^3$ was an integer, so we could simplify the floor function.
However, this time round we have $n^{\frac{2}{3}}$, which does not have to be an integer. :eek:
So, can we not simplify the floor function now? (Thinking)
Nope. We can't. (Doh)
(Worried)
So, is the inner loop executed $\sum_{j=2}^{3n^{\frac{2}{3}}} \left ( \lfloor n^{\frac{2}{3}}- \frac{j}{3} \rfloor+1 \right )$ times ? (Thinking)
evinda said:
(Worried)
Something like that... except that $j$ goes up with steps of $5$.
To simplify it, you might substitute $j=5i+2$... (Thinking)
What you will have, is more or less a arithmetic sequence.
For a complexity analysis, we would typically round it up to a worst case scenario. (Thinking)
For $j=2$, we have these values for $k$: $2,5,8, \dots, 3n^{\frac{2}{3}}$ and for $j=7$, we have these values for $k$: $7,10,13, \dots, 3n^{\frac{2}{3}}$, right? (Thinking)
So, is the inner loop maybe executed $\displaystyle{ \frac{1}{2} \cdot \left ( \lfloor \frac{ 3n^{\frac{2}{3}}-2}{3} \rfloor+1\right ) \cdot (3n^{\frac{2}{3}}-2) }$ times? (Thinking)
Let's see...
The number of times the statement [m]key++;[/m] is executed is something like:
N(2,5,8, \dots, 3n^{\frac{2}{3}})
+N(7,10,13, \dots, 3n^{\frac{2}{3}})
+N(12,15, \dots, 3n^{\frac{2}{3}})
+ \dots
+N(3n^{\frac{2}{3}})
where $N(S)$ is the number of elements in the set $S$.
To be fair, the upper limit is a bit more complex, and slightly lower.
So if we calculate this, we'll get a number that is an upper estimate for the actual number of times.We can write this approximately (erring on the upper side, which corresponds to the "worst" case) as:
\left(\frac{3n^{\frac{2}{3}} - 2}{3}+1\right)
+\left(\frac{3n^{\frac{2}{3}} - 7}{3}+1\right)
+\left(\frac{3n^{\frac{2}{3}} - 12}{3}+1\right)
+ \dots
+1
How many terms are that? (Wondering)
