Chemical energy into mechanical.
The human body operates at an efficiency of 18-26% in converting chemical energy into mechanical energy, meaning that 74-82% of consumed energy is utilized for other bodily functions, such as maintaining body temperature and metabolic activities. To perform a task requiring 1000 KJ of mechanical energy, one must consume a minimum of 3864.15 KJ, assuming 26% efficiency. The excess energy is not stored as fat but is used for essential metabolic processes. This highlights the distinction between mechanical work and overall energy expenditure in the human body.
  • Understanding of energy conversion efficiency
  • Basic knowledge of human metabolism
  • Familiarity with mechanical energy concepts
  • Awareness of caloric intake and expenditure
  • Research the principles of energy conversion in biological systems
  • Explore human metabolic pathways and their energy requirements
  • Learn about caloric balance and weight management strategies
  • Investigate the role of thermoregulation in energy expenditure
Fitness enthusiasts, nutritionists, exercise physiologists, and anyone interested in understanding the relationship between energy consumption and physical performance.
peripatein
Hello,
Given that our body is 18-26% efficient in converting chemical energy into mechanical, does that mean that 74-82% of what I consume is not burned? Furthermore, assuming a certain task requires 1000 KJ, how many meals 2000 KJ each will I need to consume for completing it without gaining fat?
Chemistry news on Phys.org
The efficiency is measured in terms of desired output. The Mechanical output is 18-26%, the rest is used in other bodily activities like maintaining our body temperature.
For the second question, just find out the energy whose 18%/26% is 1000 KJ.
It is burnt either to serve another needs, or burnt - and lost. Think why you are sweating when running - to get rid of excess heat. Where do the excess heat comes from?
So let me get this straight. Let's say I am to climb a mountain and most of the energy is spent on attaining a certain altitude. So chemical energy turns into mechanical energy which is in turn converted into potential energy. Supposing I would consume about 1000KJ in the process of climbing. Once I attain the desired altitude I'd like to compensate myself for the calorie loss but without gaining any weight. Does that mean that I can eat up to 1.18-1.26 of 1000KJ, hence 1180-1260KJ?
Nope. You need to eat that much amount whose 18% is 1000 KJ. That would be minimum of 3864.15 KJ (for 26% efficiency).
But won't the rest 2864.15kJ be turned into fat?
!? It won't. As mentioned previously, the rest will be consumed in other metabolic activity. Human body is designed to live, not to do mechanical work.
The rest of the energy is required to sustain the life in Human body. That 26% is the "efficiency" of the human body to do mechanical work only, so it accounts only mechanical energy, not other metabolics.
Yea, don't get hung up on the "efficiency" word too much. They're referring to mechanical motion specifically, but you need to do a lot more than just move around in order to continue to exist.
This reminds me of the "humans only use 10% of their brain" fallacy. Your brain has to keep you breathing, and keep your heart beating, etc... So, having 10% of anything in your body to do anything more than simply keep you from collapsing into a blob of (mostly carbon) goo is nothing to look down on.
  • · Replies 19 ·
9K
  • · Replies 24 ·
