What is the end point pH when HCl reacts with NH3?
The end point pH when 50 mL of 0.2 mol/L HCl reacts with 50 mL of 0.2 mol/L NH3 is determined by the formation of NH4Cl in solution. At the equivalence point, the solution contains NH4+ ions, which are responsible for the pH change. Given that NH3 has a Kb of 1.8x10^-5, the resulting pH can be calculated using the hydrolysis of NH4+, leading to a pH of approximately 5.1.
  • Understanding of acid-base reactions and neutralization.
  • Knowledge of the dissociation constants (Kb and Ka) for weak bases and acids.
  • Familiarity with the concept of equivalence points in titrations.
  • Basic skills in performing pH calculations using equilibrium expressions.
  • Study the hydrolysis of ammonium ions (NH4+) in aqueous solution.
  • Learn how to calculate pH at the equivalence point in acid-base titrations.
  • Explore the relationship between Kb and Ka for weak acids and bases.
  • Investigate the concept of buffer solutions and their pH stability.
Chemistry students, educators, and anyone involved in acid-base chemistry or titration experiments.
applesnjanono
Calculate the end point pH when 50 mL 0.2 mol/L HCl solution reacts exactly with 50 mL 0.2 mol/L NH3 (equivalent to NH4OH) solution.
NH3 Kb=1.8x10^-5
I have no idea how to even attempt this question. Can someone please help me? Thanks.
What is the composition of the solution at the end point? What ions are present? Only one them can change solution pH - which one?
  • · Replies 20 ·
9K
12K
