How Do You Calculate the pH of a Mixed NH4OH and NH4Cl Solution?
  • Thread starter Thread starter tua28494
    Chemistry Ph
The pH of a solution containing 0.65 M NH4OH and 0.35 M NH4Cl can be calculated using the Henderson-Hasselbalch equation and the dissociation constants of the compounds involved. The equilibrium concentration of OH- is determined to be 0.000033 M, leading to a pOH of 4.5 and a final pH of 9.5. The calculations also consider the dissociation of NH4+, which contributes to the overall acidity of the solution. This approach confirms the importance of accounting for both basic and acidic dissociations in buffer solutions.
  • Understanding of buffer solutions and their properties
  • Familiarity with the Henderson-Hasselbalch equation
  • Knowledge of dissociation constants (Kb and Ka)
  • Basic skills in logarithmic calculations
  • Study the Henderson-Hasselbalch equation in detail
  • Learn about the dissociation constants of weak acids and bases
  • Explore buffer solution preparation and its applications in chemistry
  • Investigate the effects of concentration changes on pH in buffer systems
Chemistry students, self-learners in analytical chemistry, and anyone interested in understanding buffer solutions and pH calculations.
tua28494
This isn't really homework, Its just a problem I'm trying to learn to solve. I'm not taking a chemistry course so I'm learning on my own.
Calculate the pH of a solution that is 0.65 M NH4OH and 0.35 M NH4Cl.
Well we can calulate the pOH = -log(OH-) and 14-pOH = pH
I guess I need the equilibrium concentration of OH-.
here is the chemical formula. I believe is necessary
NH4OH -> NH4SUB]+/SUP] + OH-/SUP]
the Kb/SUB] =1.5 x 10-3SUP]
Without using the Henderson–Hasselbalch equation, Can I do this?
also different Kb value.
The NN4CL will completely dissociate adding 0.35 NH4
NH4OH -> NH4+ + OH-
0.65-x. 0.35+x. . x
H2O + NH3 -> NH4+ + OH-
Kb =1.8 x 10^-5 = [NH4+][OH-]/[NH3]= (0.35+x)(x)/ 0.65-x
x = [OH-]=0.000033 M
pOH = 4.5
pH = 14 - pOH = 14 - 4.5 =9.5
This is correct by accident.
You look at the dissociation of NH4OH, but you ignore acidic dissociation of NH4+.
NH4+ <-> NH3 + H+
Why?
My bet is that if you will try to do calculations using your approach and based on this reaction, you will get almost the same result, again accidentally.
For very small x (compared with 0.35 & 0.65), is (0.35+x)/(0.65-x) substantially different from 0.35/0.65?
methods
  • · Replies 20 ·
9K
