The dimension of the fine structure constant
The discussion revolves around the dimensionality of the fine structure constant (alpha) and its implications in various unit systems, particularly in relation to Planck units and electrical conductivity. Participants explore theoretical and conceptual aspects of alpha, including its derivation and interpretation across different systems of measurement.
  • Some participants assert that the fine structure constant is dimensionless, while others question this assumption based on the implications of Planck units and electrical resistance.
  • One participant presents a calculation suggesting that if alpha is dimensionless, then the resistance in Planck units must equal one, proposing that alpha might have the dimension of electrical conductivity.
  • Another participant emphasizes that in Gaussian units, electrical conductivity is also dimensionless, which is a common assumption when discussing alpha.
  • There is a discussion about the universality of Coulomb's Law and how it leads to the conclusion that alpha is a dimensionless quantity derived from the strength of the electrostatic force.
  • Some participants clarify that the reciprocal of resistance is conductance, not conductivity, indicating a potential misunderstanding in terminology.
  • A participant expresses concern about the simplification of notation in physics, advocating for a more explicit representation of dimensions and units in equations.
Participants do not reach a consensus on the dimensionality of the fine structure constant, with multiple competing views remaining. Some assert its dimensionlessness while others propose alternative interpretations based on unit systems and calculations.
Discussions include references to various unit systems (Gaussian, cgs-electrostatic, cgs-electromagnetic) and their definitions of electrical quantities, highlighting the complexity and potential for misunderstanding in dimensional analysis.
Koilon
Everyone "knows" that the fine structure constant (alpha) is a dimensionless number, but I am troubled by the fact that the Planck unit of resistance must be one - if that is true - and that strikes me as suspicious. I wonder if anyone can shed any light on this.
I present the complete calculation here:
In cgs units, Planck's constant, the speed of light and the Newtonian gravitational constant are, respectively:
H = 6.6260755E-27 g.cm^2/sec = M.L^2/T
C = 2.99792458E10 cm/sec = L/T
G = 6.6873E-8 cm^3/g.sec^2=L^3/M.T^2
Solving these equations or the Planck units of mass, length and time, repectively, we get:
M = SQRT(H.C/G) = 5.45020877E-5 g
L = SQRT(H.G/C^3) = 4.055503739E-30 cm
T = SQRT(H.C/C^5) = 1.352770435E-40 sec
Now, the charge on a electron is:
Q = 1.60217733E-20 SQRT(g.cm/mu) = 4.803206799E-10 SQRT(epsilon.g.cm^3)/sec,
where mu and epsilon are magnetic permeability and electrical permittivity, repectively. Multiplying these two values, we get:
Q^2 = 7.695589045E-30 (g.cm^2/sec).SQRT(epsilon/mu)
for the cgs value of the square of the charge on an electron.
Now, (g.cm^2/sec) is the dimension of Planck's constant and SQRT(epsilon/mu) is the dimension of conductivity or the reciprocal of resistance. So, the dimension of the square of charge is the same as the dimension of Planck's constant divided by resistance:
Q^2 = H/R
However
alpha.H/2.Pi = 7.695589115E-30
if
1/alpha = 137.0359895.
So, if the fine structure constant is dimensionless, and
Q^2 = 7.695589E-30 = alpha.M.L^2/2.Pi.T.R,
then R must equal one in Planck units. It makes more sense to me to say that alpha has the dimension of electrical conductivity.
You have to be careful what your electrical units are. In Gaussian units (epsilon == 1), electrical conductivity is also dimensionless. This is what people are assuming when they say that \alpha is dimensionless. Jackson's E&M text has a whole appendix dedicated to this.
There's not really a need to make any assumptions about what is or isn't dimensionless in deriving the fine structure constant. It really comes from the understanding that \alpha is just the strength of the electrostatic force made dimensionless.
Regardless of the units involved, we can write Coulomb's Law as \vec{F} = k_e \frac{q_1 q_2}{r^2} \hat{r}. Expressing the charges in terms of e, we can write q_i = n_i e, where n is clearly dimensionless. Then, the magnitude of the force will be F = k_e e^2 \frac{n_1 n_2}{r^2}. The factor k_e e^2 is clearly universal, so it represents the dimensionful strength of the electrostatic force.
Given that [F] = \frac{ML}{T^2}, and that [r^2] = L^2, it follows that [k_e e^2] = \frac{ML^3}{T^2}. As it happens, [\hbar c] = \frac{ML^3}{T^2}. Thus, the dimensionless combination must be \frac{k_e e^2}{\hbar c}. This will hold generally, no matter what system of units you're using. The only difference will be in the specific form that k_e takes.
no, \alpha is dimensionless, whether or not we define the unit of charge as derived from M, L, T so that \epsilon_0 = 1 or leave it as some dimensionful value as in the SI system. in the electrostatic cgs system, the unit charge is defined so that the Coulomb force constant (what in SI is: 1/(4 \pi \epsilon_0)) is the dimensionless one. then the dimension of electric charge is L3/2 M1/2 T -1, it doesn't have its own unique dimension of "stuff", and
\alpha = \frac{e^2}{\hbar c}
but, in a general system of units, then
\alpha = \frac{e^2}{4 \pi \epsilon_0 \hbar c}
in either case, \alpha is dimensionless.
Gaussian units
Was I NOT careful about my electrical units?
The Gaussian system of units uses cgs-electrostatic units to measure electrical quantities and, in cgs-electrostatic units, epsilon is, indeed, 1 while mu is 1/C^2. On the other hand, the Gaussian system of units uses cgs-electromagnetic units to measure magnetic quantities and, in cgs-electromagnetic units, epsilon is 1/C^2, while mu is 1.
So, it is not correct to say that in Gaussian units epsilon equals 1. It is also not correct to say that electrical conductivity is dimensionless! The CRC Handbook of Chemistry and Physics, 41st edition, page 3180, gives the dimension of resistance as:
R = time/permittivity.length = permeability.length/time.
Multiplying the two right-hand sides of this equation together gives the dimension of the square of resistance as:
R^2 = permeability/permittivity.
Since, electrical conductivity is the reciprocal of resistance, the dimension of electrical conductivity is SQRT(permittivity/permeability) is ANY units.
"Jackson's E&M text" is not familiar to me. A search on the Web leads me to believe the you are referring to "Electromagnetic Theory" by J.D. Jackson. I will be sure to look up the appendix you mentioned at the earliest opportunity.
you're right, i was being stupid. sorry about that post.
Koilon: I'm a particle physicist, where we use "natural units" in which c=1. But rbj's post is correct - the fine structure constant is dimensionless in all unit systems.
jackson's textbook is the standard textbook for graduate-level E&M.
Conductivity is not the reciprocal of resistance. The reciprocal of resistance is conductance.
I feel that I need to back up and clarify a couple things.
First, I understand that practicing physicists and mathematicians are accustomed to "simplify" their notation by any and all sorts of conventions and omissions but, just as Alfred Tarski once decried the sloppy notational practices of mathematicians and propounded the maxim: NO NOTATION WITHOUT DENOTATION to rectify it, I decry it among practicing physicists and go further to add the maxim: NO DENOTATION WITHOUT NOTATION.
In the present context, the practice of particle physicists of setting Planck's constant, the speed of light, and the gravitational constant to one and leaving them out of the notation is a case of DENOTATION WITHOUT NOTATION. Another case is the practice of leaving out the dimensions. That is like leaving dx or \partialy out of a differential equation.
I also understand the PRACTICAL advantage of SI units for a PRACTICING physicist, but I am more interested in physical reality and the notations used to model it. There are no conventions in reality and I hold that conventional "simplified" notations complicate, rather than simplify, by removing symmetries from notation that are inherent in the physics.
For example, not to get into a lengthy exposition, simply witness the symmetry of physical reality brought out in the notation simply by using arbitrary units of mass, length, time, permittivity, and permeability as our base units, instead of mass, length, time and current:
Q^2 = \frac{ML^2}{T}\sqrt{\frac{\epsilon}{\mu}}\ \ \ \ \ \ \ \Phi^2 = \frac{ML^2}{T}\sqrt{\frac{\mu}{\epsilon}}
I^2 = \frac{ML^2}{T^3}\sqrt{\frac{\epsilon}{\mu}}\ \ \ \ \ \ \ \ P^2 = \frac{ML^2}{T^3}\sqrt{\frac{\mu}{\epsilon}}
D^2 = \frac{M}{TL^2}\sqrt{\frac{\epsilon}{\mu}}\ \ \ \ \ \ \ \ B^2 = \frac{M}{TL^2}\sqrt{\frac{\mu}{\epsilon}}
H^2 = \frac{M}{T^3}\sqrt{\frac{\epsilon}{\mu}}\ \ \ \ \ \ \ \ \ \ E^2 = \frac{M}{T^3}\sqrt{\frac{\mu}{\epsilon}}
C^2 = T^2}\frac{\epsilon}{\mu}\ \ \ \ \ \ \ \ \ \ \ \ \ \ N^2 = T^2}\frac{\mu}{\epsilon}
G^2 = \frac{\epsilon}{\mu}\ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ R^2 = \frac{\mu}{\epsilon}
where
Q = electric charge
\Phi = magnetic flux
I = electric current (magnetic potential, )
P = electric potential (magnetic current)
D = electric flux density
B = magnetic flux density
H = magnetic field intensity
E = electric field intensity
C = capacitance
N = inductance
G = conductance (thank you, Parlyne)
R = resistance
Surley, this has pedagogic advantage if nothing else.
Second, in my original post I probably should have made it more clear that I was thinking in terms of ARBITRARY units. Physics does not depend on which units you use. If you leave out all of the numerical values down to "However" and change "g", "cm", "sec", "epsilon" and "mu" to "mass", "length", "time", "permittivity" and "permeability" - it is just algebra (or operational calculus) in terms of arbitrary units.
So far, I see nothing but what amounts to a tired litany of dogmatic assertions that the fine structure constant is dimensionless and a complete failure to address the evidence presented in my original post that this would imply that the ratio of permittivity to permeability is always unity!
rbj: How did you get the superscripts in T^3/2M^1/2Y^-1 without using Latex?
Koilon: you've got to cool it, and think about what it is you're saying!
No, this is just wrong. There is absolutely nothing wrong with setting \hbar=c=1 and expressing all quantities in units of energy. I leave it to you to figure out exactly what UNIQUE factors of Planck's constant and c you need to include to get any unit you require. Since these factors are ALWAYS UNIQUE! I see no reason to include them one way or anther.
[\quote]
see rbj's post.
Why don't you cool your jowls for a second and stop trying to insult people who know what they're talking about! I made a mistake in my post, and I already apologized about that. But Parlyne and rbj did a good job explaining things, and I think that your tone can do with a refresher. The fact that you did not recognize Jackson's name suggests that you have not seriously studied these things, and perhaps you should go back to the basics before riding a high horse in, claiming to be smarter than the smartest physicists around, finding flaws in 100-year-old accepted facts!
No comment.
