Undergrad Is the Chirality Projection Operator Misused in This Scenario?
The discussion revolves around the proper application of chiral projection operators, specifically the left-handed projection operator, P_L. A participant expresses confusion about obtaining both left-handed (LH) and right-handed (RH) components when applying P_L to a spinor composed of Weyl spinors. The response clarifies that the issue arises from using the Dirac basis instead of the Weyl basis, which affects the representation of the spinors. In the Weyl basis, P_L should yield a spinor with only the LH component, aligning with the expected outcome. Understanding the basis used is crucial for correctly interpreting the results of chiral projections.
Aleolomorfo
Hello everybody!
I have a doubt in using the chiral projection operators. In principle, it should be ##P_L \psi = \psi_L##.
$$ P_L = \frac{1-\gamma^5}{2} = \frac{1}{2} \begin{pmatrix} \mathbb{I} & -\mathbb{I} \\ -\mathbb{I} & \mathbb{I} \end{pmatrix} $$
If I consider ##\psi = \begin{pmatrix} \phi \\ \chi \end{pmatrix}##, with ##\phi## and ##\chi## Weyl spinors.
$$ P_L \psi = \frac{1}{2} \begin{pmatrix} \mathbb{I} & -\mathbb{I} \\ -\mathbb{I} & \mathbb{I} \end{pmatrix} \begin{pmatrix} \phi \\ \chi \end{pmatrix} = \frac{1}{2} \begin{pmatrix} \phi-\chi \\ \chi - \phi \end{pmatrix}$$
I get a spinor which still has the RH and the LH component. Shouldn't I get something with only the LH component and the RH's equal to zero?
Yes, but you have to be careful to use the same basis for the spinors and the matrices.
This is written in the Dirac basis, not the Weyl basis, so the spinors in this basis do not have the ##L## part in the upper component and the ##R## part in the lower component. (It's a good exercise to figure out what pure left-handed and pure right-handed spinors do look like in this basis.)
In the Weyl basis, ##\gamma^5## is diagonal, so ##P_L## should be a matrix with only one nonzero component, in the "upper left" corner with the left-right convention you are using.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 32 ·
