Choose a ball at random from a randomly selected box - alternative way
  • Thread starter Thread starter Rikudo
    Ball Box Random
The discussion revolves around a probability problem involving the selection of a ball from one of two boxes, each containing different quantities of balls. Participants are exploring various methods to calculate the probability of selecting a white ball, questioning the assumptions and definitions related to probability in this context.
  • Participants discuss the definition of probability and its application to the problem, with some attempting to calculate favorable outcomes versus total outcomes. Others question the validity of assuming equal likelihood of outcomes and explore the implications of different selection methods.
The discussion is active, with participants providing insights and raising questions about the assumptions made in the original calculations. Some have suggested alternative interpretations and methods, while others emphasize the need to consider the probabilities of selecting each box and the balls within them.
There is an ongoing debate about the correct interpretation of the sample space and the conditions under which the probability definitions apply. Participants are also considering the implications of different counting methods and how they relate to the problem at hand.
Rikudo
There are 2 boxes. box A contains 20 white balls and 20 black balls. Box B contains 10 white balls and 5 black balls. A box is chosen at random, then a ball is taken at random from the chosen box. What is the probability that the ball is white?
##P = \frac {n(A)}{n(S)}##
https://www.physicsforums.com/threa...-random-from-a-randomly-selected-box.1034377/
First of all, I would like to point out that this is the same exact question from what is being discussed in the thread above.
In that thread, the problem is solved by adding the probability of taking white from box 1 and taking white from box 2.
Now, I am trying to solve this problem with a different and straightforward way.
We all know that probability is the ratio of the number of favorable outcomes ##n(A)## to the total number of outcomes ##n(S)##of an event.
Or, simply put: $$P = \frac {n(A)}{n(S)}$$
So, let's find the quantity of those two variables.
1. Find ##n(A)##
This one is obvious. This is just the total number of white balls in both box. So, $$n(A)= 20+10=30$$
2. Find ##n(S)##
Now, this one is quite complicated. First, we can choose the 1st box and then choose ANY balls from both boxes. Second, we can choose the 2nd box and then choose ANY balls from both boxes.
So, $$n(S) = the\,number\,of\,box \,\,X\,\,Total\, number \,of \,balls = 2 (20+20+10+5) = 110$$
Hence, the answer is $$P = \frac {30} {110}$$
But, this is not the correct answer. What mistakes did I make?
This is your mistake. This is only true if all the outcomes are equally likely, which is not the case here.
Consider this extreme example: Select one of two equally-likely boxes, one with only one thousand white balls and the other with only one black ball. The black ball has a 0.5 probability of being selected. Each white ball has 1/2,000 probability of being selected.
Rikudo said:
We all know that probability is the ratio of the number of favorable outcomes n(A) to the total number of outcomes n(S)of an event.
But, this is the definition of probability itself. So, isn't that should be true for any cases?
That is true if you are talking about the rate that the outcomes will occur given a large number of independent trials. But the OP is counting the number of possible outcomes that would be counted as event A versus the total set of results, not their rate. If you read the entire post, he is counting the number of white balls in the experiment versus the total number of balls in the experiment. He is not talking about how many white ball outcomes there are in N independent trials.
##\displaystyle P(\text{white})=P(\text{box 1 AND white})\,\text{OR}\,P(\text{box 2 AND white})=\frac{1}{2}\cdot\frac{20}{40}+\frac{1}{2}\cdot\frac{10}{15}=\frac{7}{12}##
That is the correct answer from the other thread. From the denominator of this final result, we can conclude that the possible total number of ways is multiple of 12. Is this assumption correct?
If yes, then:
In post #1, we get that the total ways is 110, which is not the multiple of 12. How can this happen?
No. You are confusing the number of possible outcomes with the probability of those outcomes. They are not the same. You got in the habit of simply counting up the number of ways that something can happen without considering the probabilities. That only works for a certain class of "counting" problems. This is not that type of problem. Most of its parts are simple counting, but this problem introduces some simple probability calculations also. You should take a hard look at what they are doing and why. Look at my example on post #2 and notice how different the probabilities are from simple counting of the balls. One ball has a 1/2 probability and the others have a 1/2000 probability.
I found something that discussed the relationship between addition of probabilities and number of ways.
Here is what it says:Suppose the event can happen in two ways which cannot concur and let ##\frac {a_1}{b_1}##, ##\frac {a_2}{b_2}## be the chances of the happening of the event in these two ways respectively. Then out of ##b₁ b₂## cases, there are ##a_1 b_2##, in which the event may happen in the first way , and ##a_2 b_1## ways in which the event may happen in the second; and these ways cannot concur . Therefore, the chance that the event will happen in one or other of the two ways is: $$\frac {a_1 b_2 + a_2b_1} {b_1b_2}$$ Which is equal to $$\frac {a_1}{b_1} +\frac {a_2}{b_2}$$I do not understand why the total number of ways is ##b₁ b₂## instead of ##b₁+ b₂##, though...
Suppose you attempt a probability problem. There are two possible outcomes: you get the right answer; or, you get the wrong answer. Only one outcome is favourable. Hence, the probability that you get the right answer is ##\frac 1 2##. Always. Regardless of how hard you study, and regardless of how easy or difficult the problem is.
  • Love
Hi @Rikudo. A simple probabilIty-tree diagram may help:
Probability of picking Box A and then a white ball is 0.5*20/40.
Probability of picking Box B and then a white ball is 0.5*10/15.
Overall probability of picking a white ball is 0.5*20/40 + 0.5*10/15.
Again, you seem to be ASSUMING that all the possible final results are equally likely and you only have to count them up. That is the starting point of the subject of probability but it will not get you very far.
Look at the tree diagram OF PROBABILITIES in post #9 of @Steve4Physics . He labeled the choice of each box as 1/2 probability. But what if there is some preference for choosing the first box? Suppose it has a ribbon that people like and it is chosen 2/3 of the time, leaving 1/3 for the other box. Better yet, what if the ribbon made that box probability 0.654321? Then the problem solution can not be obtained by simply counting possible outcomes. You need to start learning more techniques than simply counting the possible outcomes. You need to learn how to deal with calculations of conditional probabilities without relying on counting.
Because it is not the total number of distinct possible outcomes. It is just the result of mathematical manipulation.
You have to get the sample space S right for this to work: every outcome has to be equally likely.
For this problem, if you choose some outcome in S at random, there should be a 50% chance that it corresponds to choosing a ball from box 1. That means half of the outcomes in S should be for box 1 and the other half for box 2. That can't happen if you're just pooling all the balls together and choosing one at random since box 1 has more balls than box 2.
Suppose we adjust the number of balls in each box so that each box has 120 balls while keeping the ratio of white balls to black balls in each box unchanged. Now if we pool all the balls together and choose a ball at random, there's a 50% chance it came from one of the boxes. Box 1 will have 60 white balls and 60 black balls so that the probability of choosing a white ball from box 1 is still 1/2. Similarly, box 2 will have 80 white balls and 40 black balls so that the probability of choosing a white ball from box 2 is 2/3. We could express the sample space for this latter configuration as {(1, w1), ..., (1, w60), (1, b1), ... , (1, b60), (2, w1), (2, w2), ..., (2, w80), (2, b1), ... , (2, b40)}. The first number of the ordered pair corresponds to which box a ball belongs to, and the second item labels the specific ball.
The total number of white balls is 140, and the total number of balls is 240. The probability of choosing a white ball is therefore 140/240 = 7/12. This calculation works because the sample space was explicitly constructed so that each outcome is equally likely.
The way you were looking at it, the sample space was something like {(1, w1), ..., (1, w20), (1, b1), ..., (1, b20), (2, w1), ..., (2, w10), (2, b1), ..., (2, b5)}. Here, the outcomes aren't equally likely. If they were n(box 1) = 40 while n(S) = 55, so p(box 1) = 8/11. But the problem assumed choosing either box was equally likely, that is, p(box 1)=1/2.
I also wanted to point out your initial calculation for n(S) is wrong. There are no outcomes corresponding to selecting a ball that came from box 1 when you initially chose box 2, and vice versa.
  • · Replies 29 ·
