peterlonz
- 7
- 1
I don't wish to ask dumb questions about basic LED applications but ...
Yesterday I bought a 12 mcd, 5mm Dia, red LED, through hole mount.
It was to replace an unexpected failure of the previous unit: supposed to suit 12VDC supply & containing a built in resistor.
The application is a 12VDC regulated, 2 amp capable, PSU.
The original LED was nice & bright & easily seen outdoors.
This was good because the 240VAC power on/off rocker switch containing a red neon is not sufficiently bright
My replacement LED is relatively dim & I need to cup my hand over it (when outdoors) to be sure its on.
Now by chance I made a silly mistake & used a 100 ohm resistor instead of the 300 Ohm which is what I calculated should be used.
So I am expecting the LED to fail soon, but it should be much brighter surely with the higher current.
I can't figure out this dilemna.
I suspect 12 mcd (@ $0.25 ) is probably a poor choice but there seems very little choice between this low output & the much higher rated 5000 mcd & above.
Suggestions please?
Suggestions please?
