Choosing the Right Radiator for Your Vehicle
  • Thread starter Thread starter Party Pants
The discussion revolves around the performance issues related to the radiator of a five-month-old Integra, specifically addressing the vehicle's inability to exceed 70 mph. Participants explore the relationship between radiator function and vehicle speed, as well as potential causes for the performance limitation.
  • One participant questions the connection between radiator function and the inability to reach a certain speed, suggesting that unless the car is overheating, the radiator should not be a limiting factor.
  • Another participant explains that while radiators can have the same physical dimensions, their performance can vary significantly based on the surface area exposed to fluid streams, which is crucial for cooling efficiency.
  • It is noted that radiator and engine efficiency generally improve with speed, and overheating is more likely to occur in low-speed situations or when idling.
  • Concerns are raised about potential obstructions affecting airflow to the radiator, such as aftermarket modifications or a malfunctioning thermostat, which could lead to overheating.
  • One participant emphasizes that a properly functioning stock radiator should suffice unless there have been modifications that increase heat output.
  • Another participant suggests that if the vehicle cannot exceed a certain speed, it may be due to issues with the injection or ignition systems rather than the radiator.
  • Questions are posed regarding the circumstances surrounding the speed limitation, such as whether it has always been present or if it developed suddenly, and the driving conditions prior to the issue.
  • Participants recommend checking the air filter and ensuring the radiator core is clear of debris to rule out airflow issues.
Participants express differing views on the role of the radiator in the vehicle's speed limitation, with no consensus reached on whether the radiator is a contributing factor. Multiple competing explanations and hypotheses are presented regarding the underlying issues.
Participants highlight the importance of thorough troubleshooting, suggesting that assumptions should be avoided and all potential factors should be examined.
Party Pants
Are all radiators the same? I've got a five-month-old Integra and already I have done a radiator replacement because the one stockfitted on the engine bay can't allow the Integra to breach the 70 mph mark. I looked around at an auto radiator shop called http://www.overnightradiator.com/ The replacements available for my Integra looked all the same to me. I looked them up at the specs sheet but I can't get the whole picture, they might be all empty talks, you know what I mean? I figured to look for info first before I get a replacement. I'm a little green on this subject, so may I ask you guys what I should get?
I don't understand what the radiator has to do with the vehicle not being able to attain a certain speed. Unless the car is overheating, it doesn't.
Radiators can have the same physical size, but differ in performance. The one thing that is the most influential to its performance is the surface area that is exposed to the fluid streams inside. The area is created by folds, bends, fins and anything else that can be done to make the exposed area as large as possible. Usually, for a car, the radiator is sized for the power output of that paricular engine. There are other aspects that can have an effect, but that is the biggie.
Also, radiator and engine efficiency both increase with speed until you get to your top gear and radiator efficiency continues to increase from there. A car should not overheat because of going too fast, most die due to driving in 1st gear too much (ie, in traffic) or while not moving.
Unless you've done engine modifications that would increase the heat output, the stock unit should be more than adequate for any normal climate. As a possible complication, check to make sure that there are no obstructions to the air or fluid flow in the area. An aftermarket fancy grill, for instance, might not let enough air through.
The first thing that I would investigate, however, is to make sure that you have the proper thermostat and that it's in good working order.
Why can a 5 month old Integra not go above 70mph?
You shouldn't be needing to replace any parts like radiators after 5 months. And, as others have said, I don't see how the radiator is limiting the speed.
More info please.
You should check the thermostatic valve, which is typically placed somewhere in the coolant-loop (either near the radiator or near the engine block - See your workshop manual for the specific location). These are typically mechanical units, and thus may vary in calibration. Thus, if you have a unit with a slightly higher than normal opening temperature and you are in a hot climate, your engine may tend to overheat. These valves aren't too expensive, so the easy choice might be to simply to replace it, and see if it helps...
As others say: There is NO way a badly functioning radiator will limit your top speed. It may cause your engine to overheat if you run it at high rpm's for extended periods, but more likely you would see the engine overheating while standing still and idling for long periods (as this is the situation where the least amount of air pass through the radiator, even despite the radiator fan operating).
If your car simply won't go beyond a fixed speed, it is much more likely due to a restriction in the injection (or ignition) electronics. In that case you could possibly get a replacement chip for the engine, without this artificial limitation. Most car factories provide such "tuning chips", and otherwise there are a number of companies specializing in making them.
All the above is good input but i have a few questions
when did this 70 mph cap occur?
has it always been this way or did it just happen?
what were the driving conditions prior to this mph cap?
with todays car designs for max MPG and highly aero dependent the front of the car is really restricted regarding air input. since the intake air intake and grille to the radiator are both up front, i suspect the intake air filter and radiator may have got plugged to the point of now working to max efficent. did you check the air filter?
were you driving on a real dusty dirt road just before the car started acting up?
did you blow out the radiator core with an air nozzle before you took out the radiator?
we do not assume anything when we trouble shoot so you got to look at everything
  • · Replies 22 ·
  • · Replies 22 ·
28K
  • · Replies 118 ·
14K
